Mounting Locations (XM, iPod)
Old Nov 12, 2005 | 07:21 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I just purchased an Alpine CDA-9847 for my Formula, and have decided to place a second order from Crutchfield to get the iPod and XM radio equipment.
My question is, where are the best locations, out of the way, to mount these two items? The XMDirect box is like 4.5"x1.5"x5" and the iPod unit is about the same size. Since these cars don't have glove boxes, I am sort of scratching my head as to where there is accessible room in an out-of-the-way spot to put this stuff.
Any suggestions would be appreciated, and pics would be doubly appreciated!
Thanks a lot.
Old Nov 14, 2005 | 07:57 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The boxes should fit under the set. Just keep an eye out for leaks and never leave the window down or Ts out (if you have them). Corrosion damage is NOT covered under warranty.
Old Nov 14, 2005 | 09:39 AM
Bull's Avatar
Engine: LT1; None
Thanks for the reply. Do you just screw the box down right through the carpet, or do you cut out a square of carpet and set the box directly against the metal floorpan?
Old Nov 14, 2005 | 10:00 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I don't think if would be a problem grounding the box, but see if the instruction say to keep the box isolated from the chassis ground.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
JFry
Aug 19, 2015 01:25 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
