Bose is rediculous
Old Dec 2, 2005 | 05:40 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Bose is rediculous
Well the car came with no radio and there are like 600 different plugs to plug into the back of an aftermarket radio. Do they make some special harness for this application? Or am I going to have to dread this and rewire everything? Thanks guys, searching didnt answer it.
Old Dec 2, 2005 | 06:07 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I am not sure what Bose system the F cars came with, but if it is the same as in the Vettes, it is easier to change everything and rewire.
If you look at the harness and it has some clear tubing with a silver wire (common ground) in it, that is your first sign that the system is going to be a headache if you dont rewire.
1992Z28!
Nov 19, 2015 07:33 AM
scottmoyer
Sep 7, 2015 07:06 PM
rusherta67
Car Audio
Aug 31, 2001 03:50 PM
Saywhut
Car Audio
Jan 17, 2001 10:46 AM
