big subs
Old Dec 18, 2005 | 11:53 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
big subs
Do you really need big subs for a good sounding setup. I don't want to take up the room in my car for big subs. I want to beabile to put stuff in the back. My brother has 2 12's in his car and it sounds like it has way to much bass. I have this radio at home and it sounds perfect. But is there a way to get that sound in my car. I pretty much have the highs and mids figured out. But am still working on the subs. Can I use a set of 6.5 inch subs like my home stero and have it sound like it also. I manliy listen to rock and techno. But will listen to everything else. Except mybe country. Thanks in advance for the help. Adam :-)
Old Dec 19, 2005 | 07:05 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No, you don't need big subs. I have a pair of 8" subs in my girlfriends car and it sounds fantastic. There are plenty of 10" subs out there designed to work in small enclosures too.
Getting as small as a 6.5" might be pushing it, but there are some 6.5s out there that can play plenty deep... unfortunately, you really need to use those in a ported enclosure, and by the time you factor in box volume and port volume, usually it would have taken the same or less space to put a 10" sub into a sealed enclosure.
Oh... and don't forget that you can get by with just 1 sub too, you don't need two of them. That alone will help you save a ton of space.
If your brother's car has "too much" bass, it's not because he used 12s, but because he doesn't have the system set up properly. Whether you use 1 8" sub or 10 18" subs, if you tune it properly, the bass won't overpower the rest of the music unless you want it to.
Old Dec 19, 2005 | 09:26 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Just tossing an idea out there: ED's EU-700. 6.5" woofer with a huge xmas. A few people have done crazy installs with them. If you poke around that forum you should be able to find his build thread.
No idea how they sound. You just said 6.5" sub and this is what I thought of They're suposed to be decent drivers but don't expect to be able to get that low with them.
Old Dec 19, 2005 | 09:31 AM
Jim85IROC's Avatar
Did they not put the t/s parameters anywhere on that site, or did I just manage to miss them? I'd like to see how they model compared to the 8" Tangbands. Judging by their "suggested" ported enclosure, they might be pretty similar, but who knows what their "suggested" enclosure is actually doing.
Old Dec 20, 2005 | 03:17 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Use 1 sub in an enclosure you gan take in and out of the car if you need the room... make sure the wires don't short out when not plugged into the box.
Old Dec 20, 2005 | 07:13 PM
I'm lazy. lol. I have t-tops so I can't have a box up there. Plus this is my daliy driver and I don't know when i'll be having to cart stuff around from day to day.
The only place I might have a place for a box is in the spare tire area. But I like to have my spare. Is there a way to have a small box on the drivers side under the cardboard thing. Adam :-)
Old Dec 20, 2005 | 07:27 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have one 10" subwoofer and an amp in the rear of the car. You can still strap the T-tops down in their bag also. With the woofer so close to the Hatch glass, ( maybe 18"-24" from glass), it makes way more than enough bass!!
300 watt Amp
1 10" Subwoofer with 0.80 cu. ft. air space.
Sounds great.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
meeklay812
Oct 1, 2015 03:46 PM
