How did U guys power your Sat Radio?
Old Dec 26, 2005 | 06:40 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I bought myself a sat. radio yesterday and the only thing I don't like is that it came with a Cigarette plug to power it and I don't want to use it. Is there anyway to power it without seeing the wire? Are there more than just the cig lighter power plug available?
Old Dec 26, 2005 | 07:07 PM
9177's Avatar
I cut the end off and routed the wired behind the dash and it comes out above the radio. Put in a relay for the amp turnon circuit and now it only turns on with the radio.
Old Dec 26, 2005 | 07:11 PM
Kurt04's Avatar
I dunno if I would cut the end off, but you might be able to find one with a plug to plug in your fuse box.
Old Dec 27, 2005 | 03:37 AM
Guest
Guest
Posts: n/a
I would go with 9177's suggestion.
There aren't any that I've come accross that plug into the fuse box....
But yeah, just cut the end off and hardwire it into the powersource.
Old Dec 27, 2005 | 09:22 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
^^^ With a fuse of corce.
Old Dec 28, 2005 | 07:09 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Which one did you get? I just unscrew the caps, and run a wire around the metal piece over top of the fuse, and then screw the cap back on. For the ground, I just wrap a wire around the ground on the adapter. Make sure you tape it up. This way, you're not destroying the adapter incase you decide to sell it or use it elsewhere. Splice those wires in with your acc and ground wires on the radio harness and you're good to go.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
jbd1969
Aug 17, 2015 07:06 PM
Street Lethal
Aug 14, 2015 08:25 PM
