finally its done, back seat amplifier
Old Jan 5, 2006 | 01:36 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
here it is boys and girls. i'm happy with it, might do something about the cut edge of the carpet around the plexiglas, thinking might sew some vynle which i used inside the box and have it wrap around to the back. so I will have the material actually cover a little more of the plexiglass as i had to pull it tight and use some 2 sided tape. and I will put velcro on the back as well
hope you enjoy, cheers
blake
for my full system outline, you can visit my page at
my 91 camaro site, on the stereo page
Old Jan 5, 2006 | 02:11 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Looks great! I wish I could do the same with my amplifier, it's about the same size, but I have a 4-piece back seat. I'm thinking of redesigning the sub box and "flying" the amp over the woofers. Maybe sometime after tax return.
Old Jan 5, 2006 | 10:12 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Very nice work
I actually converted over to a solid rear so that I could mount my amps back there. I wouldn't have problems fitting them in a split rear (they're fairly small), but I also wanted room to mount my crossovers, distro blocks, etc
Old Jan 5, 2006 | 08:40 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
its pretty cramped in there, I'll tell ya that. that and this amplifier is freakin huge
Old Jan 6, 2006 | 06:36 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
mines bigger
i'd like to do that, but i've got split seats, and i dont think either one of my amps would fit in one, MAYBE the diamond. i think im gonna have to build an amp rack and some more weight in the back
Old Jan 6, 2006 | 01:39 PM
Al Hasse's Avatar
Originally posted by Gummie
Very nice work
I would convert to a solid backrest, but I had the split one re-upholstered not long ago, which means I'd have to do the same to a replacement solid piece. Too much $$$.
Old Jan 6, 2006 | 01:55 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
that 0AWG wire looks awfully small!
so where do you plan on putting all your other amps?
Old Jan 6, 2006 | 07:46 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
its not o gauge its actually 4 gauge into the dist blocks, then 8 gauge (2) for each pos and negative into the amplifier.
other amplifier (4 channel one) I'm going to put in the back cubby hole area. just hidden away
Old Jan 7, 2006 | 11:41 AM
ScrapMaker's Avatar
what kind of power are these amps? 8AWG is actually a little small for some amps... 4AWG is pushin' it sometimes... but as long as it's not too long 4AWG it's alright...
Old Jan 7, 2006 | 02:21 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
viper d.2500.1
something like 2000 rms @ 2 ohms bridged
it has dual connections for Positive and negative
so two 8 gauge in, 2 8 gauge ground
I see the connections are bigger, can accpept 4 gauge,
Old Jan 8, 2006 | 03:35 PM
ScrapMaker's Avatar
so you are powering, what, (5) 18" Brahmas?
and you would for sure need 0AWG or bigger...
your amplifier draws over 160 amps... so I guess you probably have two yellowtops along with at least one powermaster alt, or some custom high amp alternator?
Old Jan 8, 2006 | 09:23 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
no just 3 10" subs
Old Jan 8, 2006 | 09:32 PM
ScrapMaker's Avatar
sounds like quite the example of extreme overkill...
what kind of 10's need 700WRMS a piece?
Old Jan 9, 2006 | 01:10 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
better to over power than under power. and its 2500 watts @ full throttle on the amplifer, gain will be turned down as well as no bass enhancment. subs are oly mtx blue thunder right, dont drive car, but worst case scenario when or if they blow, they will be replaced with 3 10" alpine type R's
they subs are parrellel , each is 4 ohsm, so it will actually e a 1.3333 load, so even more power.
and also I will be upgrading my alternator, so no worries there
fellow owner said he had 12" of 8 gauge from dist. block to amplifier and I have less that that, said it was fine. just less power(as he's into spl) I dont need that full power output.
I'm just a little familiar with stereo stuff
Old Jan 9, 2006 | 02:16 AM
ScrapMaker's Avatar
Well I'm sure the previous owner had good intentions... but do you seriously think that an 8AWG wire has any place on an amp that you have wired to (theoretically) push 2500WRMS (I don't think it would make it that high though.)
No offense but have you ever looked at one of these charts?
Wire Guage versus Amperage Transmission
without looking at the chart, in my own head, I would have said never use 8AWG (and I know you're using TWO,) on any amp with more than 300 watts...
heck, if you go to the store, you'll see the different wiring kits that show the wattage their intended for... the 8AWG kit goes up to like 400 max or something..
hopefully you'll upgrade your wiring before you ever turn the gain on your amp above 10%.
I mean this amp is a wicked beast... I'd probably run double nought from the 300AMP alternator to the main battery, and double nought to the back of the car where I have a solenoid controlling a secondary battery... then I'd run quadruple nought to the distro then double 2AWG to that 2500D... I bet you can squeeze them in...
I'm only dealing with ~1400WRMS and I'm running/was running 1AWG wire to the distro, as well as the 1AWG to the amp.... I'm only looking at about 150amps total... so I don't need quite as much...
but just in case, when I wire up my new car, I'm going to put 0 or 00 just for future flexibility.
Old Jan 9, 2006 | 03:19 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
looks great but to much work for me heh
Old Jan 9, 2006 | 08:23 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
fellow owner had 12" of 8 gauge wire from dist. block to amplifier, I have half of that
he has however 0 gauge from battery to dist block, yellow top optima and said he had a 105 amp alternator at one time. upgraded to some crazy one as he is totally into spl has two 18" RE in there. hes actually a member of this board. i'm moving onto bigger and better things. this can be delt with later, as I dont even drive the freakin car(no motor, no trany, no susp. doesnt' have a deck, so I couldn even listen to it, and doesn't have a battery. even when done, I wouldnt not be worried about the amplifier as minimal to no gain will be used. but eventaully dont worry I will upgrade
battery is goign to be in trunk. run 0 gauge from battery to amplifier, then dual 4 gauge from dist. blocks into amplifier
Old Jan 9, 2006 | 10:03 PM
ScrapMaker's Avatar
sounds a lot better
if you have access to the amp... what fuses does it have?
Old Jan 10, 2006 | 01:12 PM
stitchop's Avatar
Car: 91 firebird
I just spent an hour looking at your car on the car domain link, great job, your work looks very good.
Old Jan 10, 2006 | 08:14 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
hey thanks man, very much appriciated, trying to do my best and most thourough job on it. tryign to do everything myself, only way to learn
wont be painting, did that to my malibu. had enough of that, lol , I will paint engine bow however
I dont believe there were any fuses actually in the amplifier from what I saw, I didn't actually go over the amplifier too thourgoly , I had to ask previous owner how to take inputs for cables off, also found cross over etc is hidden under the viper snake head emblelm
Old Jan 11, 2006 | 10:03 AM
ScrapMaker's Avatar
weird... no serviceable fuses?
Old Jan 11, 2006 | 07:27 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
didn't see any?
Old Jan 12, 2006 | 09:52 PM
Gummie's Avatar
Car: 88 GTA
I'm 99% sure that JL doesn't have fuses on their amps and I'm pretty sure that there are others out there too. There was a guy on here a while ago who said that he soldered his memphis fuse holders together with some heavy gauge wire at the direction of his dealer.
Old Jan 13, 2006 | 02:38 AM
ScrapMaker's Avatar
no offense.. but Memphis is crap.. I had the 1500D for like a few days until I swapped with eD
Old Jan 13, 2006 | 10:12 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Nice work!
Old Jan 13, 2006 | 11:55 PM
Gummie's Avatar
Car: 88 GTA
None taken. Everyone is entitled to their own opinions after all. Some people will still swear by sony/lightening audio Personally, I don't know enough about memphis to comment one way or another.
My point was that a few reputable (like it or not memphis is considered reputable) companies sell/reccomend running amps without fuses.
Old Jan 15, 2006 | 03:01 AM
ScrapMaker's Avatar
All I know is that the 1605D I had was not 'defective' by Memphis' standards... but no matter how I hooked it up in my car, I would hear a light 'rumble,' that did not increase with volume (meaning, it wasn't an input problem.) even did it with no source connected.
Sent it back, got a new one, (even checked the serial number.) Same exact problem.
Redid all my wiring again (even though I knew it was good to start with since I have had several other amplifiers.) No difference..
bought the nINE.1, and now my subs hit harder, no static, and it looks much better in my opionion... cleaner...
I just think the memphis has really changed over the last year or so, and maybe they cut costs somewhere, resulting in the amps picking up interference... (like from the fuel pump maybe, or anything...)
and about the fuse thing... I can't believe anyone would recommend that... because then the amp could easily burn up, right? it seems that you would just put in a bigger fuse instead...
edit: oh yeah, and scratch my earlier reference to the 1500D... I have no experience with that, and I have heard EXCELLENT things about it... I only had this year's 1605D
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Polo Z03
Sep 10, 2015 06:43 PM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
