first time installin a headunit need help
Old Jan 17, 2006 | 10:32 AM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
hey im tryin to put in a headunit in my 91 firebird wat color wires need to go from the cd player to the car the headunit is kinda somewhat new
Old Jan 17, 2006 | 10:59 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Buy a wiring kit. There is no good reason to cut up your factory wiring, and plenty of good reasons why not to. It will make the installation MUCH easier, and it will make removal easier, and the harness only costs about $5-10.
If you've suffered the misfortune of finding that some idiot before you already managed to hack your wiring, then do a search and you'll find 300 posts with all the info you need.
Old Jan 17, 2006 | 03:31 PM
MoroteZ28's Avatar
yeah im new at this how does the wiring kit make it easier??
Old Jan 17, 2006 | 04:28 PM
Guest
Guest
Posts: n/a
A wiring harness will allow you to hook up your head unit without having to cut and splice any of the factory wiring or the wiring of your new headunit.
Just trust us, if you dont know what you're doing then just spend the extra few bucks to make sure that it gets done right.
Old Jan 17, 2006 | 04:51 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
The wiring harness makes it a lot easier because the wires from the wire harness coming out of the radio and the wire harness you buy all match up color to color. IF you just match the color to color on the harnesses it should be a piece of cake. Just dont cut the plugs off the factory wires in the car. That will make it a pain in the butt.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
