How many amps for 2 type s subs
Old Jan 18, 2006 | 07:24 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
How many amps for 2 type e subs
I bought 2 Alpine 12" Single-Voice-Coil 4-Ohm Subwoofers, and one Alpine 700W Class D Bridgeable Mono MOSFET Amplifier. I was wondering if i should get another amp, one for each sub. I'm only doing this once and want it to be right.
the amp spec's are as follows;
700W peak output @ 2 ohms, bridged
200W RMS (continuous) @ 4 ohms
Subs;
Continuous Power Handling 200W
Peak Power Handling 600W
Impedance 4 ohms
The 700 is peak at 2 ohms, and they are single voice coil 4 ohms.
Will 2 be safe/louder?
Old Jan 18, 2006 | 07:27 PM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
do you know the what kind of rms the amp will put out at 2 ohms? cause i'd say just wire the subs to 2 ohms and run it that way.
Old Jan 18, 2006 | 07:29 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
350W RMS (continuous) @ 2 ohms, 20Hz - 20kHz, 0.3% THD
Old Jan 18, 2006 | 08:35 PM
Dracul's Avatar
Engine: 5.7
Transmission: 5spd
hmm.. you'd probably want to either get another amp, or sell your current one and go bigger if you want to stay single amped. generally i like to feed my subs a little more than their rms rating, just to make up for power loss and the fact that amps aren't 100% efficient.
Old Jan 18, 2006 | 10:20 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I would sugest against another alpine amp mainly due to cost.
Here are a few sub $200 amps that all put out some pretty good power (around 1,000 watts).
http://www.ikesound.com/product-product_id/2821
http://www.ikesound.com/product-product_id/2307
http://www.ikesound.com/product-product_id/3918
Another option is a NINe.2x or a NINe.1 from ED.
Nothing wrong with having extra power on tap, just be careful with it.
Old Jan 19, 2006 | 08:19 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
oxiderush, that wouldn't happen to be the alpine mrp-m350?
I'm looking to buy an mrp-m350, so if you have that and you want to move onto another amp, let me know.
Another option for you, If you go to pricegrabber.com, I found an mrp-m350 for $140, with shipping and tax. Instead of buying a new single amp, try buying a second mrp-m350, and each sub will have its own amp, at 200 rms @ 4 ohms.
Old Jan 20, 2006 | 11:01 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Actually, i know someone who works at best buy and I got it for $110.00, so buying another one isn't a big deal.
The amp is the m350. Really like keeping it all alpine. If price is the only downfall, that i'll get another one.
And no, i can't get anything for anyone else. It was hard enough to get him to buy my stuff.
Old Jan 20, 2006 | 12:39 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Good thing you said that. It was my next question
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
raymondandretti
Sep 27, 2015 06:43 PM
