Upgrade to power antenna
Old Feb 19, 2006 | 08:23 PM
galletti's Avatar
Car: 1988 IROC Convertible
I have an 88 IROC Convertible which didn't come with a power antenna. I'd like to add a factory style one but can't seem to find the relay under the passenger side dash area. Is this because since it wasn't there from the factory, the relay won't be there either? TIA.
Old Feb 19, 2006 | 10:05 PM
silverta8702's Avatar
more than likely the relay is on the the antenna itself , all the aftermarket ones i put on come with it built on the motor . if not just build a relay
Old Feb 19, 2006 | 10:14 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The stock power antenna does have the relay mounted behind the panel that is beneath the map pocket.
If it was not factory equipped with a power antenna, I would seriously doubt that the relay would be there.
Old Feb 20, 2006 | 02:39 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
mine came with a power antenna but its broke now and i cant find a new one.
Old Feb 20, 2006 | 11:37 AM
Jade Grey's Avatar
Engine: 305TPI
The replacement antenna is GM#88891017 and it cost about $125. Earlier replacement antenna numbers have been discontinued. Below is a picture of the unit.
If the only problem with your power antenna is a broken mast cable, then check out these threads.
Old Feb 20, 2006 | 06:57 PM
galletti's Avatar
Thank you for all your comments. Actually, I bought an original used antenna with the factory harness with three wires going from it to the antenna. I guess I'll just look for the connector a little more carefully. If it's not there, what kind of wiring would I have to do to get it to function. Most aftermarket antennas I've seen only have two wires. Also, I tried an aftermarket before but the relay was too far up the shaft and it would fit the inner fender hole that's there.
Old Feb 20, 2006 | 07:40 PM
Jade Grey's Avatar
Engine: 305TPI
The comments in my second post were made towards maroon88iroc.
Galletti, you would need a 6 pin relay like a SMP RY603 or equivalent. The one side of the relay would have power, ground, and the pink lead from your radio. The other side would have the three leads from the power antenna.
Old Feb 20, 2006 | 08:35 PM
Car: 88 IROC
thanks for the info man but i am not going to spend anywhere near $125 bucks for a new antenna.
Old Feb 20, 2006 | 11:04 PM
Jade Grey's Avatar
Engine: 305TPI
You should be able to find a good used stock power antenna for about $50.
Supposedly the aftermarket Metra power antenna does not fit our cars all that well.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
