4 ohm sub measuring 2.5 to 3.2 ohms
Old Feb 23, 2006 | 10:16 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I measured the resistance across the terminals on my Pioneer TS-W300R subs (two of them measured seperately, with SAME results) rated at 4 ohms, readings bounced between 2.5 to 3.2 ohms. On average, I'd say 2.9.
I plan on running them in parrallel on a 2 ohm Apline mono amp. Is this stil okay to do ?
I've been running them off their own channels, two bridged channels of a 4-channel amp. The amp was rated for 4 ohms bridged. That amp recently died.
Old Feb 23, 2006 | 11:49 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
The 4 ohm rating is a nominal impedance whereas the 3.2 ohm reading you are getting is the DC resistance. Although the DCR is typically lower than the nominal impedance, IMO 2.5 is a little low. I am sure you can still run them parallel to that alpine mono amp without issues, just monitor it for a while.
Old Feb 24, 2006 | 07:12 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
what surprises me is how much the DCR differs on the two subs. Pioneer is usually much more consistant than that. That much of a difference in DCR is likely to have a pretty noticable effect on the Qts and other T/S parameters.
Old Feb 24, 2006 | 07:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Are these new subs or have you been using them for some time? If the speaker aren't new I wander if the coils didn't get over heated. What meter are you using? And they shouldn't be bouncing around a lot, may be at first but it should settle right down.
Old Feb 24, 2006 | 08:47 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
A $20 radio shack meter. It is a digital display. The meter bounces around unreadably at first, and then steadily bounces between 2.5 and 3.2.
I have been using one sub for about 8 months, and the other, for about 4 months. Both show the same bouncing.
If this will not kill my Alpine, then it's all good.
BTW, I cut the pieces for the bottom of the box last night. Tonight I'm going to assemble the bottom, and work on the top of the box. I'm eager to test the differences between the good 'ol plate, and the praised enclosure .
Old Feb 24, 2006 | 11:40 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Enclosures for the win! Just wait, this spring/summer you will be contimplating building a fiberglass box to save weight and give you some extra volume without taking up any more space
Old Feb 24, 2006 | 12:19 PM
Gummie's Avatar
Car: 88 GTA
double post
Old Feb 24, 2006 | 09:02 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
My saw and drill are on the job, no building till tomorow.
HOWEVER, I did order my amp today, alpine mrp-m350. nice little 350 rms @ 2ohms. Should be here Monday or Tuesday.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
lewandom
Oct 1, 2015 08:15 AM
