Obvious wiring problem. Please help.
Old Feb 28, 2006 | 06:18 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
I'm getting really frustruated. I know it's some little thing I'm overlooking, and I just can't find it.
I bought a headunit recently. I installed the wiring harness and connected the wires to the headunit wires. I plugged in the headunit, and the headunit didnt work. Not only that, but the instrument panel and gearbox fuses went out. So I replaced the fuses for the instrument panel, and noticed the radio fuse was out too...So I switched that one as well. So now the fuses are both new and I assumed the radio didnt work before cause the fuse was gone (I never used the old one). So I plug the unit in again, and again it didnt work...and again, the instrument panel lights went out...Only this time, the fuse didnt blow! Guh...
Anyways, I'm positive the wires are all correct and they are not exposed...So I dont have the faintest idea what's going on. But I'm about to stomp on the head unit. haha.
Old Feb 28, 2006 | 06:51 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Check your ground wires, i had a strange happening where first the dash lights wouldnt come on but the headlights would, then the headlights wouldnt come on and the dashlights would, Then the dash lights would come on and the headlights would be on, but the HU would be off.. It turned out that the ground i chose was a bad one, I put a ground on the tranny tunnel, and all my problems went away.
Old Feb 28, 2006 | 06:57 PM
hihighost's Avatar
Car: 1987 Camaro
Alright I'll take a look. Yeah, the headlights come on, but the dash and gearbox wont. Thanks a lot.
Old Mar 1, 2006 | 07:06 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Check your wires, disconnect the dimmer wire, try again...
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bull86
Aug 10, 2015 05:43 PM
