Rear 6x9's
Old Mar 12, 2006 | 07:06 PM
cdudka29's Avatar
Car: 1985 Camaro
Engine: V6
Transmission: 4 Speed OD
Rear 6x9's
I bought 6x9's for the back, but i dont have the sail panel location to put them in, i was wondering what others have done to resolve this?
Old Mar 13, 2006 | 12:14 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Re: Rear 6x9's
You mean you pulled the cloth cover and there's no speaker holes? Or are there 4x6's and 4" woofers back there?
Either way you can unbolt the plate that's over the speaker hole, go out and buy some sheet metal/wood, cut a hole for the 4x6, and install them that way.
Welcome to the board btw
Old Mar 13, 2006 | 01:00 AM
cdudka29's Avatar
Car: 1985 Camaro
Engine: V6
Re: Re: Rear 6x9's
theres no cloth there, in mine its just a plastic panel
Old Mar 13, 2006 | 01:18 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
I don't have any sopts for the speakers either, I'm going to get boxes to put them on the rear shelf. Like a sub box, but smaller. I know summit sells some.
Old Mar 20, 2006 | 08:48 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
if theres no holes in the sail panel plasic then id cut some out and then you should see the metal where gm puts the metal plates in for the 6x9s then you can make one out of mdf or get some stock ones from somewere and put them in yourself....any option gm del. is pretty easy to install.
heres a pics of my car with my speaker mounting plates removed and stuff in this tread to get a look at what your dealing with: https://www.thirdgen.org/techbb2/sho...d.php?t=208787
i dont have a pic of the hole youll want to have in your sail panel plastic but im sure youll find one easy on ebay or the above sponsor links in parts for sale.
Old Mar 27, 2006 | 05:49 PM
ChevyRS-305's Avatar
I think that’s what my car was like before the previous owner cut 6x9” holes in the panel and put plywood behind it so he could screw the speaker in. I am going redo the whole thing and make a custom fiberglass panel to weir the speaker is molded in the panel and is visible. You may want to think about doing something like that if you’re into the whole custom thing and can fiberglass of cores.
Old Mar 28, 2006 | 02:16 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
weird, I've never heard of a 3rdgen w/o the 6x9 opening...
I mean, I've heard of the subwoofer setup... but not a solid wall...
is that custom or what?
Old Apr 1, 2006 | 08:56 PM
Car: '81 Trans Am
Engine: 6.6L
was it a factory radio deleate car...did you check you rpo codes...do you have any pics???maybe a good history topic!!!!
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
zayne0
Aug 24, 2015 07:22 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
