Amp Shuts Down
Old Apr 2, 2006 | 10:40 PM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
Amp Shuts Down
Ok, the other day my amp shut down for a few minutes and then came back on. I had it working really hard, it was really hot out and I accidentally put a bag on the amp. So I figured it got too hot and shot down. Didn't do it again until the other day. It was shutting down and then comming back on. Stopped again now it shut down and wont come back on. The power light blinks. So I know its getting power. I checked all the fuses and they're good. Any ideas as to why the power light blinks? Is my amp dead? Its a Pioneer 760amp BTW.
Look exactly like this one only silver
http://www.bass-enterprises.com/Prod...rs/GM-X862.jpg
Old Apr 2, 2006 | 10:59 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
checked all your grounds maybe one might be loose.
hmm, ive never had a problem like that.
it could be over heating, where is it located?
Old Apr 2, 2006 | 11:28 PM
Engine: 305TPI
If it was a bad ground the light wouldn't blink would it? Its located in the back on top of the fuel tank. Had it like that for a while and never had a problem. Just started having problems.
Old Apr 3, 2006 | 12:11 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I had a bad ground for a while with a previous amp. The amp would turn on but would turn off the instant I would try to play any music.
Old Apr 3, 2006 | 07:31 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Double check the grounds! Then check the resistance of speaker. Are you trying run that thing at 2 ohms bridged?
Old Apr 3, 2006 | 05:45 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i had a problem like this when i used a positive wire with a push in type fuse. the fuse looked fine, but it was actually blown. happened two or three times over the course of a few years. if you have a push in fuse positive, replace the fuse. might work
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
ironbmt
Sep 27, 2015 06:00 AM
