Amp question
Old Apr 11, 2006 | 02:08 PM
lowgas&rubber's Avatar
Car: 97 b4c camaro
Engine: 350 lt1
Amp question
If I bought a mono amp and it didnt specify that is was bridgeable, could you still bridge it and get full power and performance?
Old Apr 11, 2006 | 02:16 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
How are you going to bridge it? The manufacture are ready did (more then likely).
Old Apr 11, 2006 | 02:24 PM
GTA_IN_T.O's Avatar
Bingo!!!!!!!
Thats correct if its a mono amp then there is nothing to bridge its already done.
Queston is how low can it go (ohms)
Old Apr 11, 2006 | 03:02 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Originally Posted by NEEDAZ
How are you going to bridge it? The manufacture already did (more then likely).
(edited for readability )
This makes more sense when you consider that most headunits are really 8 chanel amps that are bridged down to 4 IIRC.
Pretty much what everyone said already. You can't bridge it but you can run multipul subs off it. The only thing that matters is final load.
Old Apr 11, 2006 | 03:27 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Good catch. I can do that too. Channel and multiple.
And you right on the HU. 8 single ended amps operating in BTL (Bridge Tied Load) mode for 4 outputs. No you can't bridge a HU.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
