Subs make poping noise.
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
Ok I have 2 12' (800 watts)MTX subs with an MTX 800.1 mono amp. I also have 1 Infinity amp 4 ch and 1 Kenwood amp 4 ch as well. I believe the Infinity amp is 90 watts rms per ch and the Kenwood is 70 watts rms per ch. The Infinity amp is hooked up to a pair of 4x6 kappa's and 6.5 Infinity components. While the Kenwood amp is hooked up to a pair of 6.5 Kicker components. 4 gauge wire from batt to amps and ground as well. I also have a 200 amp alternator.
Alright with that out the way the problem only happens when the car is off after a few minutes of playing music the subs begin to make a poping noise even after I lower the volume. What can be causing this?
P.S. At first I tought it was the battery so I change that and got a yellow top optima but problem cont.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
sounds like a blow voice coil or coils to me..... Then again the sound quality wouldn't be **** either then though and this is coming from someone with not a whole lot of audio experience too so take it with a grain of salt.
All i know is the numerous subs i blew voice coils in made a popping sound the way you describe it but, also sounded like crap after i *blew* them.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Whats the voltage on the battery when it starts doing this?
If it was a voice coil it would do it all the time...
Im guessing that the amp doesnt like the lower voltage.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Defiantly not a blown coil. I agree with 84z28350, check voltage @ the amp with a multimeter. Voltage to the amp is about the only thing that’s going to change with the car off vs the car running.
When you did your battery upgrade did you beef up the grounds (chassis battery & engine chassis)?
Car: 91 Z28, 86 Z28
Ok I'll check the voltage this weekend. No, I have yet to upgrade the ground cable from the engine to chassis. I'll do that this weekend as well and post what I come up with. Also what can I do to raise the voltage when the car is off?
Car: 88 GTA
Car: 91 Z28, 86 Z28
Not loud at all. Just enough to hear while I'm cleaning my wheels. It started doing it when I change the sub amp. I'm guessing it needs a higher voltage like you said than my older rockford amp that I had. But I'll find out this weekend with the meter to make sure it's that.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Its gotta be the drop in voltage...
Even though the battery has a 11.5-12v charge while the car is off, that amp might need the 13-14v from the car running to function properly.
Car: 88 GTA
Most amps are good to around 10.5 volts are so.
Car: 91 Z28, 86 Z28
No, all I changed was the amp and it's new. I'll check the manual to see that's the recommended voltage for it.
Also noticed that the sub's pop as well when I change a cd or when I change the EQ setting on the stereo. But it's just a single pop not a continues one like when the car is off.
Car: 88 GTA
I wouldn’t necessarily rule out the headunit in this case. Have you tried running everything off a portable CD player or something else along those lines with the car off? This will eliminate the HU as a possibility.
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
THE POP MAYBE THE AMP ACTUALLY TURNING OFF, TURN OFF POP, THERE NEEDS TO BE A SMALL DELAY OR TURN OFF SLOW IN THE AMP, WATCH YOUR LED ON THE AMP WHEN TURNED OFF. THE LED MAY SHUT DOWN FAST OR DIM DOWN SLOW, A FRIEND IS USEFUL, ALSO TRY TURNING THE GAIN DOWN. IF YOU HAVE MORE THAN TWO ITEMS TAPPED OFF THE REMOTE WIRE , YOU WILL HAVE TO USE A RELAY TO TAKE THE LOAD NOT THE HEAD UNIT
Engine: 305 tpi
Transmission: t-5
i just talked to my buddy, pro installer, he said to check the rca's, and your grounds,just like others have said also
Car: 91 Z28, 86 Z28
Alright thanks for all the help guys. I'll check all that stuff tomorrow and see what I find out.
Car: 89 IROC-Z
Engine: 355 TPI
I'd still like to know the voltage at the amp, car running, car off, and after the popping starts. Think that may point to a bad ground.
Car: 91 Z28, 86 Z28
I found out that it was the voltage. When running it's at 13.7 when off at 11.8 and when it starts making the poping noise it's at 10.5
Didn't have enough time to ground the engine to chassis. Also couldn't find the manual for that amp but I'm sure the voltage shouldn't be lower than 10.5. I'll ground everything properly today or tomorrow and see how much of a difference that makes. So what else would be the solution to this problem?
Also tried to lower the gain like chads89ta said and that took care of the single pop when I would change a cd while the car is on.
With that change it takes longer for the subs to make that poping noise when the car is off. But not by much only about 5 min.
Didn't have enough time to ground the engine to chassis. Also couldn't find the manual for that amp but I'm sure the voltage shouldn't be lower than 10.5. I'll ground everything properly today or tomorrow and see how much of a difference that makes. So what else would be the solution to this problem? Also tried to lower the gain like chads89ta said and that took care of the single pop when I would change a cd while the car is on.
Car: 88 GTA
Originally Posted by NEEDAZ
Thats bad. What is the battery voltage (at the battery) when this is happening?
Turning down the gain = less output = slower battery drain. That's why it took longer
What kind of power (wattage) are we talking about here and over what kind of time frame?
Car: 91 Z28, 86 Z28
Well I just decide to rewire everything. I put 1 gauge wire from the batt to the amps and ground. I also checked all the connections on the hd and organised everything since the wires were all over the place. Guess it did the trick since I had it on for half an hour and no poping.
Thanks for all the help!
Thanks for all the help! Thread
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
