Has anyone ever built a box like this?
Old Apr 16, 2006 | 05:35 PM
Faded's Avatar
Car: '91 Firebird
This is a box in the back of a 4th gen. This seems like an ideal way to store the T-Tops even with subs in the back. Just wondering if anyone had tried something like this in a thirdgen or not...
Old Apr 16, 2006 | 05:56 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
not that i've seen, but the hatches are very similar, would be possible but not easy. thats a real clean looking setup.
Old Apr 16, 2006 | 06:22 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
wow thats nice looking. but if that was my car i would realy be freak-out about my t-tops breaking when the bass hits. i think it might realy do damage to them.
Old Apr 17, 2006 | 08:46 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The bass won't damage the t-tops. I'd be much more worried about what would happen to them in an accident.
Old Apr 17, 2006 | 11:09 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
^^^ Thats what I'd don't like about that setup (been posted before). Think about them shattering and sending the side bar part with broken glass right up between the seats.
Old Apr 18, 2006 | 09:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Or right between your ears.
Old Apr 24, 2006 | 12:44 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
yeah, and the t-tops actually touch each other... it's your OPTION to put a rag in between...
I prefer the bag that the thirdgens have myself... while it takes longer to take them off, it's much easier to make the bag work with subs...
Old Apr 24, 2006 | 02:20 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
That would be awsome but I would be weary of leving my t's hanging like that...not to mention 4th gen T's are much smaller. My best solution after building my box is to leave one of my rear seats folded down...
Old Apr 24, 2006 | 02:54 PM
ScrapMaker's Avatar
I just strapped my tops in the bag over the subs... as long as they aren't hitting the subs, you're fine
Old Apr 25, 2006 | 08:58 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Would a setup like that sound as good as the "standard one" ?
In this setup the woofers are pointed slightly forward, in the "standard one" woofers are pointed straight up ? What about loading off the hatch or something ?
Old Apr 25, 2006 | 09:09 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
JUST USE A THIRDGEN T-TOP BAG, LIKE SOMEONEELSE
SAID
Old Apr 26, 2006 | 03:45 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
that setup looks awesome! makes me wish i was good at firberglass stuff.
my audio knowledge = my import knowledge, very little, i just know what sounds like a bee and what sounds good.
Old Apr 26, 2006 | 09:22 AM
ScrapMaker's Avatar
I'd rather have a bigger box, and a safer mounting location for the t-tops... like, I don't know, in a bag? strapped down?
the thought of 2 30-pound pieces of glass flying at my face really just doesn't sit well with me...
Old Apr 28, 2006 | 12:34 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Would it sound as good as the boxes where the subs are aimed straight up ?
Old May 13, 2006 | 01:53 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Bass frequencies are largely "omnidirectional", which is a fancy way of saying you can't tell which direction low frequencies are coming from. This is generally true for all frequencies about 80 Hz and lower. Thus tilting the subs backwards or forwards will make no difference, sound quality wise
Old May 13, 2006 | 01:56 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
So nothing about "loading" of the hatch ?
Old May 13, 2006 | 11:49 AM
ScrapMaker's Avatar
the only phenomenon I've noticed is that when you have a hatch-firing box, the 'higher' bass can sometimes be overwhelming... whereas, a down/rear-firing box will muffle those sounds a bit more, resulting in, what sounds like, deeper bass...
Old May 13, 2006 | 09:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Down/rear firing ? You mean woofer facing back, towards the licence plate, or down, i.e. mounted inverted ?
Old May 13, 2006 | 10:25 PM
ScrapMaker's Avatar
either way...
the best I've ever heard in a thirdgen was when I had a box that fired towards the license plate... you get deeper bass because the sound wave has more time to become 'fuller,' for lack of sonic frequency knowledge...
but basically down/rear-firing will prove to be better bang-for-buck systems...
plus you can make them stealthy...
Old May 14, 2006 | 12:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Any modifications to the inside of the car, the rear part that is ? You must have dynamated the hell out of it huh ?
Old May 15, 2006 | 12:04 AM
Engine: 305-4v
Point them towards Mecca five times a day, if you wish ... the bass frequencies are extremely unlikely to exhibit any additional sonic pleasantries
Old May 15, 2006 | 01:06 PM
ScrapMaker's Avatar
I just put some rubber behind the license plate and tightened up the tails...
Old May 15, 2006 | 10:47 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Kewl, well I already sound proofed my well pretty darn good.
I'm just wondering what to do next, try a ported box for my sub, or wait until I can get another amp and another sub, because my current setup requires me running 410W RMS into the 250W RMS single sub at 2 ohm, the sub being DVC and amp giving out 300W RMS at 4 ohm, makes it not a good idea to even try running two of those subs at 4 ohm.
But I do want more volume *lol*
That 4thGen setup deserves credit for design, beautifully crafted, however the t-top thingy uhmmmm
Old May 21, 2006 | 11:42 AM
Birdman92's Avatar
Car: '92 Firebird
Engine: V6 for now
Nice set up. I thought of doing this with a third gen, but didn't really have the room. Building a big ported box for competition is hard enough to find air space. My tops just go in the bag that runs from the back of my box (goes up to back of seat) down to the floor. No room for back seat passengers with them this way but looks clean. I love my lexan tops, don't worry about bass breaking them.
Stinger 5 farad cap, HiFonics 4 channel under sub amp, distro blocks, and Stinger amp fan hidden under hinged face plate to amp rack.
HP52TA
Feb 3, 2018 10:51 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
