The big 3 question (negative cable)
Old Jun 1, 2006 | 09:02 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I was just wondering how you guys made the cable bigger from the negative terminal to the chasis ground. Did you just add it to the terminal and than ground it, or did you actually T into the negative cable wire.
I need some suggestions of how to do this.
Right now I am runing 2gauge wire, and I need a bigger wire between the chasis and the batt. terminal.
Old Jun 2, 2006 | 02:04 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I got a pair of copper lugs from Murray's Auto Parts for like $2. I pounded 1 of them flat so it would fit between the stock battery bolt and the battery. I did the same thing for my power wire too.
Old Jun 2, 2006 | 05:19 PM
Thats what I thought. I just wasn't sure if it was a bad thing to directly ground it. However, now that I think of it, its the same thing...
AND I replaced my ground cable with a 2 gauge cable, and what a FREAKING DIFFERENCE. MY SPEAKERS HIT TWICE AS HARD AS BEFORE AND NO SIGN OF THE NEEDLE FLUCTUATING.
THIS UPGRADE IS A MUST IF YOU HAVE A STEREO.
OH, I forgot.
Whats the routing on the power wire. I see it going off to the distributor, and I am not sure how to replace it.
Can someone tell me where the power wire goes from the alternator?? I know it goes to the battery, but where else does it go? and is it easy to replace??
Thanks.
Last edited by xlwhellraiser; Jun 2, 2006 at 05:21 PM. Reason: Automerged Doublepost
Old Jun 2, 2006 | 05:28 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Huh, cool. I'll have to do that when I replace my front speakers. One of them actually shot the cone out of itself, so.. yeah. It was 10 years old though.
Frozer!!!
Jan 19, 2024 04:55 PM
Accerrito22
Aug 23, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
