Pic of my new sub box that i made
Old May 11, 2006 | 06:54 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
I was tired of my old dual 12 setup because i couldn't strap in my t-tops...so i decided to make this 10" enclosure.....im really happy with the results and it sounds great!!
lemme know what you think....
Old May 11, 2006 | 12:10 PM
TDK's Avatar
TDK
Looks Good!! I am going to start on mine tonight...
Old May 11, 2006 | 12:20 PM
GTA_IN_T.O's Avatar
You can make a box that will still allow you to strap the t-tops down........i have a box holds 3 tens........... it sits below the hooks so you can still hook the t-tops.....
Here are the pics...........
https://www.thirdgen.org/forums/2832486-post10.html
Old May 11, 2006 | 12:29 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Matt, nice box. I'm glad I'm a hardtop owner
GTA_IN_T.O - very nice MDF work
Old May 11, 2006 | 01:57 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
looks good, now go hide that wiring! just messing with ya. you notice I am not showing pics of my wiring....
Old May 11, 2006 | 07:48 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Kewlness, let me guess, Reference hmmm 1042W or 1050 or ?
Running a 1042W myself.
Old May 15, 2006 | 09:33 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Thanks for all the comments....yah its a 1052....yah i REALLY need to hide the wiring but im still figuring out the best plan of attack for that so until i do i will just have to have the spiderweb
Old May 15, 2006 | 09:50 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I'm building an amp rack that holds the t-tops, and sinking 2 12's in the well. I'm going to have 10 times the wireing mess (3 amps) but it'll all be displayed. Actually the sub box is done, and i have about 3 hours ledt in carpeting the amp rack, and tweaking it a bit.
Old May 16, 2006 | 12:31 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Specs ?
What's the RMS for the sub, and how much wattage are you going to push it with ?
Old May 16, 2006 | 05:03 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i used to have an infinity kappa in mine. i really liked it but now ive got 2 kicker cvr 10's i considered the reference subs but i figured id try something different. nice setup you have. i have an angled box in the well and mounted the hooks on the top of it so i can still have my t-top bag in there ill post pics later if yall are interested.
Old May 16, 2006 | 06:39 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Post 'em !!
Old May 25, 2006 | 01:29 PM
Car: 88 IROC
heres a couple pics. the subs are brand new i havent even screwed them down yet. im getting a new amp as well its on the way.. it is a profile 2000 watt. it does 980 watts rms bridged. i also threw a pic in of the t-top bag i just mounted the original hook things on the box granted the tops arent in the bag but you get the idea. i just dont play the subs loud at all with the bag on there. i should get grills but i dont take the tops off much at all.
Attached Thumbnails Pic of my new sub box that i made-img_0107.jpg   Pic of my new sub box that i made-img_0104.jpg   Pic of my new sub box that i made-img_0108.jpg
Old May 26, 2006 | 11:13 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
You put carpet on the spare tire compartment as well ?
That looks kewl, the carpeting all over makes it blend in real real nice.
Old May 27, 2006 | 07:16 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
... I betttt you got that setup at Best Buy correct? Haha, we carry all that stuff! Nice box though!
Old May 28, 2006 | 11:36 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah my friend is the car-fi manager and he was telling me how good the infinity stuff was so i decided to get a sub....
Old May 28, 2006 | 02:50 PM
zerogauge's Avatar
looks good.
Old May 30, 2006 | 08:39 PM
matt83z28's Avatar
Car: 83 z28
Engine: lu5
Transmission: 700r4 that works good.
Axle/Gears: G92 3.23
hey matt..
hey love that sub box with the single 10.. thats exactly what im trying to do except with a 12. see i have an infinity reference series sub that i was running inside a q logic box in the back of a neon and it was perfect for me..every piece of plastic in the car would shake like a french soldier with it pumped up. i think the sub is a 1030 or something..got it at circuit city like 2 years ago or something. but the thing is on the infinity website it says the sub should be in a box with 1.25 cu ft of volume. the q logic box only had 1 cu ft but it still sounded awesome. so i guess my question is how many cu ft of airspace does your box have, and do you think i could adapt your design to the 12? how do you expect that it would sound if i had my sub in your setup do you think it would be similar or completely different? the q logic was in the neon with the sub pointing towards the back of the car. i really like this sub and the amp i had driving it and would like to adapt them to my camaro i just got but i cant put that big ole box in there like that it would look terrible. let me know what you guys think!
Old May 31, 2006 | 10:20 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
my setup is at .85 ft^3 right now....but i blocked off the box so to that volume so it could be larger.....as far as mounting a 12" sub...i would think that it would fit because IIRC the top face is 13" wide or something like that....
Old Jun 1, 2006 | 12:01 PM
Twisted92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L 350 TPI
looking good here's a pic of mine, not the best pic but you get the idea.
Old Jun 1, 2006 | 12:33 PM
WickedTA's Avatar
Car: 85 TA
dont know if it has been said or not but you can always turn the ttop bag over to the straps are on the bottom.
Old Jun 1, 2006 | 10:23 PM
Car: 88 IROC
you can put polyfil in the box to trick the sub into thinking the box is bigger which will allow it to play lower notes. IIRC you are supposed to use like 1 lb of fil per cu ft. but idk exactly what it is i cant remember. make sure you get fire resistant polyfil though. and you can get a bag of the stuff at walmart for less than 5 bucks.
Old Jun 2, 2006 | 05:29 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
That's actually factory, or at least it's an option. Don't know if he did that or it came like that. My 87 IROC had the factory option for it also. I forget what the RPO code is offhand.
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Amillionoh7
May 24, 2020 08:01 AM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
Street Lethal
Aug 13, 2015 08:28 PM
