need install help
Old Jul 1, 2006 | 10:00 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
need install help
Hey guys, does any body know a forum that helps out with 12 volt installs. I need to wire up the gray wire (neg output) on a DEI 530T to a relay to bypass the shock sensor because the shock sensor tiggers the alarm sometimes. The shock sensor has 4 wires. green is shorter than 0.8 seconds neg multiplex input wire,blue is longer than 0.8 sec multiplex input, and then there is a red 12v constant, and a black ground wire. Anyone know what I'm talking about? Basicly it disables the shock sensor while the 530T is in use. I also need help installing rear 6x9s in a friends 2005 civic, I can't fiquire out how to get to the speakers themselves.
Please Help.
Old Jul 3, 2006 | 04:23 PM
krisb410's Avatar
So nobody knows how to wire up a relay
Old Jul 3, 2006 | 09:15 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
well i know theres a site that should help its one of these 2
the12volt.com
12volt.com
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
