should I angle my sub or not
Old Jul 2, 2006 | 07:10 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im looking to make a box for a single 10" sub in the lower trunk well. the sub will be mounted on the side of the box firing horizontally. Should I angle the sub a little bit or just mount it straight up and down. I was told that the sub will not work correctly in a sealed box if its mounted square to the opposite side wall.
Old Jul 2, 2006 | 07:59 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have one 10" sub in the rear. The box I built to sit flush with the top off the deck well. It is firing straight upward at the rear deck glass and then bounces towards the front seats. I have a Pioneer 800watt sub, and a Pioneer 1 channel 1000 watt amp. Sounds good and bumps when you need it to. I try to get a picture soon. Sweet car by the way!
Old Jul 2, 2006 | 08:20 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
Mine is facing up and I'm only running a single cerwin vega 10" with 200 watt amp and it hits very nicely when needed, built the box to go around the window motor so I can still remove it when I want
Old Jul 3, 2006 | 04:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just popped a pair of cheapo pioneer 10" subs on a plate in the back of my car. they have a very very slight forward angle and they sound awesome for not being in a proper box.
I think they sound alot better than the 12" and 15" i had in the back seat before!
jbates346
Oct 21, 2015 01:50 PM
mfp189
Sep 27, 2015 09:25 AM
Linson
Sep 21, 2015 01:08 PM
FED 387
Sep 16, 2015 12:18 PM
Night rider327
Sep 16, 2015 02:20 AM
