mounting angle
Old Sep 7, 2006 | 11:46 AM
PAformula's Avatar
mounting angle
Does anyone know what the radio mounting angle is for thirdgens?
Old Sep 8, 2006 | 06:10 PM
Raiderfan's Avatar
Car: '92
Dose it matter? As long as its flush right!?
Old Sep 9, 2006 | 11:51 AM
AllenGTA's Avatar
Car: 1987 Camaro Z28
Engine: 5.0 TPI
It does if you're using a flip out screen head unit. They can only work up to a certain angle.
Old Sep 11, 2006 | 07:18 AM
PAformula's Avatar
Yes, That's the reason for asking, Does anyone know? Is it less that 20 degrees?
Old Sep 11, 2006 | 12:49 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Gota protractor? Sit it flush on the radio trim, and eyeball it to a horizonal line. I almost want to say its more than 20 from what I rememeber. You mightbeable to put something under the rear of the headunit, and tilt it forward a bit.
Old Sep 14, 2006 | 10:19 PM
PAformula's Avatar
Its about 40 degrees. Now question is, How will that affect a Fosgate flip-down face CD player?
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
Linson
Sep 21, 2015 01:08 PM
ynk1121
Sep 12, 2015 12:27 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
