Radio Shuts Off When Brake Is Pressed
Old 10-04-2006, 07:18 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
OK, this just started happening today, whenever I press down on my brake pedal, my radio just shuts off then comes back on.
Is it a short somewhere?
Is there a wire getting pinched?
Whats causing my radio to shutoff and come back on?
Old 10-04-2006, 11:02 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Three possibilities. The first is a short. The second is a voltage drop when you hit the brake. The third is a bad ground, but this is pretty unlikely IMO.
The quick and easy way to find out is to watch both the ignition wire and the 12v wire for the deck with a DMM when you hit the brake.
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
smooth
08-18-2015 06:34 PM
Quick Reply: Radio Shuts Off When Brake Is Pressed
