no power to headunit
Old Oct 7, 2006 | 09:21 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
in my 89 formula when i bought it there was no radio harness connector, just cut wires, so i got a harness from an '87 bird and patched that in, but i ended up with 3 extra wires? all of the speaker wires are connected properly and when i connect the stock radio i hear static, but the display does not light up, and when i connect an aftermarket headunit nothing happens at all. is there a way i can just directly connect the headunit to the battery with another fuse rather than going through the whole harness?
Old Oct 11, 2006 | 12:09 PM
Firebat's Avatar
yeah, get some wire and splice into the back of the fusebox. Splice in after the fuse, not before it so it is fused.
But you have 12Volts somewhere because you get one unit to power up. Doublecheck your wiring first. Basic headunit wiring: there should be +12Volts all the time to one wire, +12Volts only when the key is on to another, ground, then all the speaker wires.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
