windows create static
Old Oct 18, 2006 | 12:33 AM
johnblaze322's Avatar
Car: 92 camaro
Engine: V6
when i listen to radio not the cd player and roll down my windows i hear a static and depending upon how load the radio is playin is how load the static is i also have a sony explod head unit
Old Dec 21, 2006 | 02:13 AM
nickx07's Avatar
similar problem
here is what i am running...
4th gen head unit wired for a external amp (96 delco/bose)
100 x 4 channel amp
kenwood 4x6 in the dash
kenwood 6x9 in the b piller
everytime i play the radio or a cd it sounds fine and crisp. however i have power windows and when i press the button to go up or down the speakers also give off a static sound much like white noise. recently when the blinkers are activated the static comes back. whats going on?
Old Dec 21, 2006 | 12:31 PM
cmznj2's Avatar
Car: 1985 Trans am
Engine: 305 tpi
Transmission: 4 speed auto
Did you run the wires yourself. All the signal wires have to be run away from electrical wires. Or you get the sounds that you are talking about
Old Dec 21, 2006 | 06:24 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Bad grounds.
Old Dec 22, 2006 | 04:31 AM
nickx07's Avatar
alright well i did do the wireing myself. a few weeks ago i wraped the RCA wires with plastic wire looms. it sounded beter at frist but now after driving the car around it came back. the RCA wires run from the head unit to the passanger foot well. then it meets the kick pannel and the 10 gauge amp power wire. the RCAs are still covered in the wire loom as both the amp power wire run under the door sill, over the wheel well to the spare tire well. could running the amp power wire with the RCAs be the cause of the problem???
Old Dec 23, 2006 | 11:06 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
How is this done? You shouldn't really run the power and signal wires together. Run the amps power and RCAs on opposite sides of the car when ever you can. Redo the grounds at the amps and take the ground for the HU out of the stock harness and ground it someplace good on the chassis. See what that does. And we have to be careful not to take over this thread from johnblaze322.
Old Dec 25, 2006 | 07:03 PM
Car: 92 camaro
Engine: V6
nah its ok im am just takein in what everyone is saying thats all i think my prob is that i ran the wires all on the same side of the car but i cant really do anything about it since i have no spare wire at this time so ill jus turn down the radio or put on the att when i wanna roll the windows down
Old Jan 21, 2007 | 02:50 AM
nickx07's Avatar
recently the static has been comming on a little soft as the winsheild wipers and blinkers are activated. whats going on? should i rewire the system?
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
dusterbd
Sep 29, 2015 08:40 AM
