Harness Question
Old Nov 18, 2006 | 09:45 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Harness Question
Ok I have a Pioneer DEH-P7500MP, and I need a wire harness adapter. I have the harness that comes out of the cd player, I just need the part that you wire to the car and plug into the cd players harness. Anyone know what type of harness I need?
Do I just buy one of those installation kits from walmart or something. Or do I need a specific one from Pioneer
Old Nov 18, 2006 | 10:01 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
you need one for the specific radio/car... can probably get one from tweeter. Alternate method: Cut and splice, a personal favorite.
Old Nov 19, 2006 | 10:30 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Don't hack the harness. Go to Walmart, or Best Buy, or Circuit City, or what ever you have nearby and get a harness for your car. They can also be order from a hundred on-line place. You need one that is specific to your car, in your case one for a 92 Camaro. You will connect that harness to the harness that plugs into the Pioneer by using solder/heat shrink tubing or good quality crimps and get then tight. Do NOT Twist-and-tape. The other option is to buy a pre-made harness/adapter. This is just like above but someone other then you made the connections. They're not as widely available and will cost more, but if you're not comfortable making the connections they are an option. You should be ably to get one at a car audio shop or you can order one. Using harness insted of cutting up the stock harness makes for a much cleaner plug-in install, you can put the stock HU back in if you need to, and keeps the stock harness intact.
Old Dec 7, 2006 | 03:14 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
The guy I bought my car from hacked the harness and I payed no mind to it. Went to put mine in and it was hell trying to figure out what wires go where. The remote turn on had to go somewhere that didn't make since, I had to test and tune. The Hayne's book was helping me all the way.
Buy the adapter at Walmart, would probably be the cheapest and will work jsut as good as one you would buy anywhere else.
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
fbirdroller
Sep 2, 2015 10:27 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
