Car Alarm Trouble
Old 12-12-2006, 01:18 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Car Alarm Trouble
OK, I couldn't find an appropiate section to post this in so i decided on here. well I've got a 93 Jeep cherokee and it has an aftermarket car alarm on it. a Python 1500HF. the problem is that the alarm will turn on jsut fine but it wont turn off when the car is started. i can however turn off when the brain is disconnected and then reconnected. anybody have an idea what may be wrong with it. i believe that python alarms are made by DEI.
Old 12-28-2006, 08:21 AM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
[quote=DBLTKE;3154455]OK, I couldn't find an appropiate section to post this in so i decided on here. well I've got a 93 Jeep cherokee and it has an aftermarket car alarm on it. a Python 1500HF. the problem is that the alarm will turn on jsut fine but it wont turn off when the car is started. i can however turn off when the brain is disconnected and then reconnected. anybody have an idea what may be wrong with it. i believe that python alarms are made by DEI.
sounds like the wire is not hooked to ignition control wire
Old 12-28-2006, 01:44 PM
Gangstajpimpin's Avatar
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
matter of fact, this is a third gen website
Old 12-28-2006, 09:02 PM
-N-
-N-'s Avatar
Car: 1984 Berlinetta
Yes, this is a 3rd gen website but I'm sure that perhaps DBLTKE was hoping that someone may have had a similar problem and be able to help, that's kind of what these forums are for.
Old 12-28-2006, 09:58 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Did you have someone else install your alarm? I would say that if you did, take it to them.
And guys, this may be a Third Gen specific website, but this is an issue with an alarm, not the vehicle itself. The vehicle that the alarm is on does not affect the alarm itself. Would have been easier to just not post if you don't have anything to say to help out, instead of being rude, this is how people get ran off and spread a bad word about this place. I have heard plenty of people talk bad about us and this site, when in-fact this site for the most part is not a bad place at all.
Old 12-31-2006, 04:47 PM
DBLTKE's Avatar
Engine: LB9, LB9
Well I was hoping that you guys would be understanding to the fact that I am having some car trouble and help me out a little. The Alarm was installed by a shop. The vehicle belongs to my shop teacher and as far as I know the problem has not been resolved. Any insight as to what the problem may be?
Old 01-01-2007, 09:24 PM
I honestly don't have any idea as to what the problem might be. I would just advise him to take it to the place it was installed at and make them look at it, and it might even get done for free since they installed it, depending on what it needs. Could just be the receiver for the remote, not sure.
bryan623
03-22-2021 06:43 PM
Reddeath210
10-06-2015 08:20 AM
hokis
08-09-2015 03:57 PM
johanlindgren
Wheels and Tires
08-06-2015 03:32 PM
Quick Reply: Car Alarm Trouble
