Sub box in back???
Old Jan 13, 2007 | 01:58 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Sub box in back???
Bit of a newbie question, but here goes... I'm thinking of adding 2 10'' subs and an amp in my Camaro.. I've heard and seen that the sub boxes that are built specifically for our wells are better than the conventional boxes, but i'm wondering, does it leave any space left if I would need to store sumthing? Would I need to keep takin the box out everytime i need some cargo space? Also, what about if I have my t-tops off?? ANY help is much appreciated...
Old Jan 13, 2007 | 03:03 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i stick my t tops behind my driver steat in the bag , for my box theres 2 styles
http://www.hifisoundconnection.com/S...id/0/SFV/30046
that sit right down in there
and
i got this one my self cause i am running 2 10's they sound great and my t tops sit fine behind the seat and could sit on top of the box if i wanted to
Old Jan 13, 2007 | 11:56 PM
Bad-Newz's Avatar
is it possible to maybe get those flat style s subs and place them in a box that can lifted or removed if u need the space?
Old Jan 14, 2007 | 06:34 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
For a vert you would need to make a custom box that can lift out at will. You could go with fibreglass to save some weight. Flat subs would be best to keep the box fairly small. You could go thie 3 8" subs also to keep the box small. There are some decent stereo shop that can do the work in Toronto or the GTA. Just stay away from the hack shops. A lot of places don't know what they are doing. I could send you some shops names to go to......I am not affiliated with any stereo shop....just competed in IASCA for a number of years and used to judge.
Old Jan 14, 2007 | 02:02 PM
91thirdgen's Avatar
google stealth box.. i forget who makes one but they go in the side where the "storage"compartment is but they only hold 1 sub so 1-12" or 1-10".. my buddy as one in his 95 trans am with t-tops and you cant even tell he has a sub until its on.. they are a little pricy but well worth it
Old Jan 14, 2007 | 06:53 PM
Bad-Newz's Avatar
Thanx billsblue89, that would be great... Any opinions on what sounds better? Im thinking 2 10'subs but im not sure if it better to run one amp or two. The factory 4X6's in the dasn and the 6X9's in the quarters have been replaced by Kaption audio speakers which sound pretty good. Maybe one 12' sub maybe be better for me I dont plan on winning any db contests, just want a lil more bottom end...
Old Jan 14, 2007 | 09:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Some dont like this type of set-up, but this allows me to still store my T-tops & they dont block the subs when i store them back there.I am running two 12in Cerwin Vega free air subs here.I have also hinged the lid so i can open this & keep a few items in the trunk space.The lock from the original locking lid has been intergrated into this lid so its also lockable.Though ive never put anything down there, except the amps!
Old Jan 15, 2007 | 03:31 AM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
I bought a sub box from crutchfields.It's made to fit the well and holds two ten inch subs.there's still room under it for storage.I put my amps down there and added handles to the box to make it easier to remove.I also put fans in the sub box to blow on the amps.Works great.
Old Jan 20, 2007 | 12:13 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Mentioned above in this post, theres two styles, one of which "sit right down in there". Im planning on going that route with two 10s, anyone have a pic of that style? Figured if post here instead of starting a new thread.
Old Jan 20, 2007 | 03:40 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
I've actually had both of those boxes in my car at one time or another. If I were you, I'd look into getting the one that rhomanski bought. The only difference is the one you want goes ALL the way down into the cargo well, and the one he bought lays flat across the first set of humps in the well. I've had both and they're identical aside from airspace. The smaller box will work fine. Those boxes are heavy to begin with, so any weight you can lose is a bonus. If money were no issue (yeah right) Q Logic makes an awesome box that matches the interior plastic. It actually looks like part of the interior panels. As far as the pictures your looking for, it will more or less look identical to the pic posted by 841LE, except w/10" subs.
Old Jan 20, 2007 | 04:14 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Cool, yea weight and SPACE is an issue for me. I checked out another thread, i saw a few pix of ones i like. I really like the setup that deadbird and a few others have. If i get the small one that goes to the very bottom of the well, i will still have a useable trunk, this car is babied, and goes real quick, but i want it to be practical as well. Thanks for the info though.
Old Jan 20, 2007 | 04:34 PM
87 IROC NC's Avatar
Car: 1987 IROC-Z28
so what do those boxes weigh? That is the thing I would be most concerned about, no sense in being able to bump down the road and not be able to put up at a stop light because i got 100lbs of speaker in the trunk. Can you post the link to the one from crutchfield too please?
Old Jan 21, 2007 | 01:07 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
my box weights 30 lbs highest box i found was like 50ish
Old Jan 21, 2007 | 02:48 PM
87 IROC NC's Avatar
Car: 1987 IROC-Z28
Thats not too bad, though maybe if I got some more weight in the back, my tires wouldnt spin as much
Old Jan 23, 2007 | 09:38 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Even with my amp there, I can still tie down my T-Tops.
Old Jan 23, 2007 | 12:00 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Here is what I did in mine. It's a 10" Alpine in a custom build slot vented box. 300RMS/900Peak sub and amp (Rockford). It's alot more than I thought it would be. The good thing about this set-up is that I take it out by only unplugging the wires and lifting out the box. Also, I don't have any t-top problems.
Old Jan 25, 2007 | 10:20 AM
STOLN's Avatar
Box and amp
Hey,
Until I build a fiberglassed box for my hatch I have just cust a piece of thick plywood with holes for 2 12's and run a 300 watt Fosgate amp to them. I have laid the board across the sides of the hatch so they are set in deep and not visible at first, using the tub as the box. Sound is excellent and lots of bass from the Alpine type s 12's, Alpine head unit as well. Cheap way to get great bass and the pressure in the car is so much that you get a headache if the windows are up. So for those of you trying to find that magic setup, try this in the interum.
Old Mar 5, 2007 | 11:27 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
hey, 91_5.7_TPI, got a question about your setup. I like the setup you have way deep down, but what is your sound quality like? Does it sound muiffled at all because its pointed towards the side?
Old Mar 5, 2007 | 02:09 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I had a JL W3 in the same exact position and trust me it doesn't sound muffled a bit. Mine was actually a bit louder aiming sideways as opposed to up. I still have the box, it's a 1.0 cubic foot ported enclosure and it sounds amazing; running off of a Rockford 300 watt amp. The SQ from a single small sub setup like this is better than the pair of subs I had in the sealed enclosure, and they were comparable subs. I ported my hatch well box and it sounded good, but I wanted the space for my nitrous bottle in the hatch so it was back to the single enclosure.
Old Mar 5, 2007 | 10:36 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
This configuration seems to make more bass than it would facing up. The guys that built the box (and they do ALOT of systems) said it is louder than what they expected. I really like the arrangment. My deck adjustes from -15 to +15. I run the amp at around 80% and the deck at -7 to -3 most of the time and it's plenty loud for me.
Old Mar 7, 2007 | 10:35 PM
urmomshot77's Avatar
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
well if u dont mind loosing the back seats, make a box outta that area, and mount your amps in there too (fits 2 12's and 2 amps easily), youll have plenty of room for your t-tops and your Well for storage...
Old Mar 8, 2007 | 12:17 AM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Hey bro, what's the dimentions of that box?
Old Mar 8, 2007 | 02:48 AM
Car: 89 IROC
Bad newz.................you could run 2 10" shallow mount subs with no problem. I was reading a comparison test with the pioneer and clarion subs in a mag last month (I think it was car audio and electronics magazine). The article chose the clarion over the pioneer for sound quality and overall sound for rock, jazz and rap. Have not heard these subs personally.
Old Mar 8, 2007 | 09:57 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I'll have to measure. The car is in the body shop now, but I should be getting it back today.
Old Mar 8, 2007 | 02:11 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
naaah dont get clarion or pioneer.. theres much better subs for the money.. Fi SSD's... or maybe some audioque sd2.5's... are you looking for just sound quality? or for them to be loud to?
Old Mar 11, 2007 | 03:33 PM
daves12secV6's Avatar
+1 for mounting in the back seat area, i did it cause u cant fit anyone back there really and i wanted the trunk space for my nitrous bottle
though im actually ripping it all out now and gonna install a simple bazooka 8inch tube in the back since im starting to get more serious with racing the car.
lol i weighed my car today and it weighed in at almost 4,000 pounds with me in it
Old Mar 24, 2007 | 11:44 AM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
Sub box
So what would be the best sub box for a 91 camaro with T-tops. i always have my tops out and some times i have people in my back seat. anyone have dimentions or anything like that?
thanks
Old Mar 24, 2007 | 12:12 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Sub box
thanks
For the most part, ANY box that uses the well is ok with T-tops. I had one which angled toward the front, and was still able to lay my tops in the back. However, I did invest in a set of grilles for the subs as T-tops weren't the only thing that went in the back.
Fast355
Dec 2, 2016 06:33 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
marcusaw
Aug 10, 2015 08:13 AM
