ported enclouser
Old Feb 7, 2007 | 12:31 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
ported enclouser
i right now have 2 type r's (10's) in a sealed box , for the well (this one right here)
http://cgi.ebay.com/CUSTOM-10-SUBWOO...QQcmdZViewItem
i am not exactly sure on each sides cubed side but i wanted to have ported box made for these 2 10''s tuned for high base but i dont want it to get in the way of the back window , any one have a nice ported box that dont get in the way at all of drivers view? most of the boxes i seen ported seemed huge but were running 12's or 15's and i was hoping mine would run a smaller cubed box made from CAR ESSENTIALS in albany would be worth it or just keep em in the current box
i had plans of building it in the takin out back seats but a few people said they just wont sound as good as in the rear
currently also waiting for jim to make some kick panels =\
Old Feb 7, 2007 | 12:32 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
You plan on continuing to use your Type-R's? You want AT LEAST 2cubic feet per sub.
Old Feb 7, 2007 | 01:27 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
even fore the 10's i thought cubes needed went down i know the 12's need at least Alpine Type-R = 1.7472 Liters for the 12's displacemnt , not sure if liters = to the cubed factor or not , but if they need for 10's say 1.0 then that would = 2 cubed , then
Old Feb 7, 2007 | 02:07 PM
Cam-aro's Avatar
Car: '91 Z28
... Still go with 2cubs PER sub. That's how I and my other guys build the ported boxes. You could get away with around 1.7 per sub, but don't take the risk of building a complete box and it being slightly below what the subs really want.
Old Feb 7, 2007 | 04:02 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
cool thanks for the advice , happen to know if built in the back seats will be enough room?
Old Feb 7, 2007 | 04:21 PM
bakerstreet's Avatar
i've built many boxes for our cars, & i have one in mine as well with 2-12's. this is what u need to do, forget about using fiberglass, since the sides & bottom wont be seen anyway. what i do first is to remove that part of the carpet, u can save it if u want to put it back one day. then i build the box piece by piece, then glue & screw together. the front & bottom side will each be one straight piece, sides one piece, the back will be 5 pieces, obviously to fit around the latch assembly. the top can be one or two pieces, & if u want to fiberglass the top over the wood, or u can cover the wood like i did take your time & in about three hours u will have a bad mother shut yo mouth. since u are using 10's just build the box as big as will fit & deal with airspace later since u will have more than enuff for 10's. mine has two 12'' vegas & it blows waves like u wouldn't believe. let me know how it turns out...
Old Feb 8, 2007 | 08:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
What?
Anyway, fiberglassing the bottom will be a more efficient use of space than building it all out of wood, but it will be more difficult and more time consuming.
Regardless of whether you do 'glass or wood, it's very important to get the airspace and the port tuning correct. If you don't, you'll have a 1-note wonder. Keep in mind that the port size is highly dependant on the enclosure volume. In other words, tuning a port to 30hz in a 1 cube box requires a totally different port than tuning to 30hz in a 2 cube box, so you have to know precisely what your airspace is before you calculate your port tuning.
I would suggest downloading a copy of WinISD so that you can experiment with enclosure volume. This will help you arrive at a suitable enclosure, and will also allow you to see what differences there will be by altering the volume or tuning frequency.
Building a sealed a box a bit too big or a bit too small is no big deal, but when it comes to ported boxes, it's critical to be accurate if you want it to sound good.
Old Feb 8, 2007 | 12:05 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i plan on having the guys over at car esenchionals (sp?) build it after i get it price quoted on a 2 cubed box , see what they say see what they think
Old Feb 8, 2007 | 12:28 PM
Jim85IROC's Avatar
After you get a price from them, let me know. I'm within driving distance from troy.
Old Feb 8, 2007 | 01:02 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
list of places i know of audio in the driving distance of troy , we got a audio place in troy that deals with more home / band audio equipment but i got some termal cubs and banana plugs from him , cool guy he gave me the boomer place and then i relized that boomer abd CE are the same place , what a dope i am
Boomer Mcloud Car Essentials
ALBANY
1021 Central Avenue
Albany, NY 12205
518.438.3000
SCHENECTADY
1702 Chrisler Ave
Schenectady, NY 12303
518.346.4091
CLIFTON PARK
1603 Towne Center Plaza
Route 9 North
Clifton Park, NY 12065
518.371.3500
QUEENSBURY
299 Dix Avenue
Queensbury, NY 12801
518.745.1300
Car Essentials - Albany
1021 Central Avenue, Albany, NY 12205
phone: (518) 438-3000
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
