Need clarification...please :)
Old Feb 22, 2007 | 10:10 PM
Gangstajpimpin's Avatar
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
I have 2 Comp VR 4Ohm Subs. I am planning on getting the Hifonics Brutus 1606D amp...unless there are some objections and a better amp has taken over.
I also need 2 6x9's and 2 4x6's. Which ones would you recommend, and would they require another amplifier to be installed? If so, how would i go about this whole opperation, and which amp wiring kit should i get?
Sorry for being a noob, but i want to get this all right on the FIRST try
Thank you in advance for helping me out!
Old Feb 23, 2007 | 09:24 PM
Engine: 3.1 V6
anybody?
Old Feb 24, 2007 | 08:26 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
the amp will be fine for that sub , what kind of price rang you looking to spend for the 6x9's and 4x6's , also they wont need to be amped i would recommend you use bass blackers on them tho
http://www.crutchfield.com/S-eyvNVzf...p?i=127BB600A2
http://www.crutchfield.com/S-eyvNVzf...p?i=127BB150A2
are the bass blockers i used
for 4x6's i use Infinity Reference 6422cf i dont have them installed yet i just nought off ebay for 20 bucks =) but as of right now i use pioneer top end 4x6's the best they got forgot there name
and 6x9's i also use the top brand of pioneer's but i plan on chnaging them out after i buy some 5.25 comp speakers
but check out jim's speaker how to here its realy good
http://www.iroczone.com/technical/Speakers/
Old Feb 24, 2007 | 08:54 AM
Engine: 3.1 V6
Thank you for the detailed reply!
The amp is rated at 1 ohm which gets 1600watts. If i split this...will each sub get 800 watts?
Old Feb 24, 2007 | 10:18 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
its always best to strt the amp and system with all bass turned off on hu and amp , then set the HU settings then turn the gain up till the wubwoofer sstart to distort , that way you wont blow them
Old Feb 24, 2007 | 10:22 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
actually you set the gain to match the preamps of your h/u.. you dont turn it up untill it distorts......
800 watts for 2 comp vr's is a bit much.. if they are the new ones... they are rated for 400rms.. but it wont be 800watts .. hifonics puts out about 70-80% of their rrated power.. so i would keep the gain on the amp turned down a little.. so your not blowing those things up
Old Feb 24, 2007 | 11:15 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
http://www.fbodyaudio.com/articlevie...cle=gains.html
thats the other artical i was looking for good read there
Old Feb 25, 2007 | 09:27 AM
TheBandit's Avatar
Engine: Poncho 350
ive heard from a bunch of car audio sites.. that you have to set it according to your h/u..
Old Feb 27, 2007 | 02:31 PM
Polecat's Avatar
set gains with a DMM.
