Passenger side audio out
Old Feb 23, 2007 | 07:24 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
I have an 89 Trans Am with stock AM/FM cassette.My problem is the power antenna, front and rear passenger speakers don't work. The left side works fine but hear static noise when I use the balance and fade to the right side, should I fix or not bother and throw out??
Old Feb 24, 2007 | 08:27 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
take out the head unit make sure all connections are on , i had my antenna come off , and as for the speaker it sounds like its blown
Old Feb 24, 2007 | 10:32 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
speakers are blown.. most likely.. adn for the antenna.. same happened to mine.. its just old and the whole thing seizes up.. i would toss that too and get a new one
Old Feb 25, 2007 | 09:31 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Update - I didn't pull the unit but decided to try a cassette tape and see what happens. Well, the passenger side speakers work but not that great. It sounds like a short or loose wire because I'm still getting a static sound when using balance and fade. When the weather warms up I'll pull the unit and investigate further...to be continued!! No luck with the power antenna yet..
Old Mar 10, 2007 | 06:56 PM
19 IROC 88's Avatar
My antenna works but I have the exact same thing going on with my passenger side speakers. I pulled the head unit and all the wires look fine. I figure that because it's both right side speakers anditbegn at the same time that it's a problem with the head unit. I plan to replace it with another GM factory unit soon and I'll let you know how it goes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
