4 AWG Power Cable
Old Feb 25, 2007 | 06:36 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
4 AWG Power Cable
I have a quanity of this 4AWG power cable and was wondering if I could use it to power a car audio amplifier? Need to know if there are any issues with this type of wire(noise,interference,insulation thickness,etc.) that would cause potential problems on a amp install. Look forward to hearing from the audio guru's. Badman
Old Feb 26, 2007 | 09:00 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Anyone? How about some replys? Badman
Old Feb 26, 2007 | 11:53 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Personally I wouldn't use the wire pictured for one reason, that's a very coarsely stranded wire. Coarsely stranded wire doesn't support as much power as a finely stranded wire, I assume that this is why they pack finely stranded wires in Amplifier hookup kits. A secondary issue although minor, is that coarse wire is not as flexible as fine wire.
I'm just speaking from a purely electrical point of view, I'm not an Audio expert by any means.
Old Feb 26, 2007 | 11:57 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Those were the first two things I thought of when I saw the picture.
Old Feb 26, 2007 | 12:06 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for the replys and info. Just trying to see if I could use whats avaliable and save some money. Badman
Old Feb 26, 2007 | 05:33 PM
cdoyle's Avatar
http://www.knukonceptz.com/productDe...?prodID=KLM4BL
only .89/ft for 4 gauge
These guys are great too, I've ordered stuff and had it within 3 days!!
Old Feb 28, 2007 | 07:12 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
I use welding cable. got it for free about 50 foot of it, maybe 2G? It aint as thick as 1G, but thicker than 4G. flexible as heck, fine strands, casing is nice and thick to avoid abraisions, and it was CHEAP!
I would avoid using what you posted for the same reasons mentioned above though.
Old Mar 1, 2007 | 03:34 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
i use welding cable also.. 4guage welding cable.. very flexible with thin strands and works great
Old Mar 2, 2007 | 12:42 PM
bbbates14's Avatar
As an electrician i can say it'll work jus fine.Wires are rated by gauge to tell how much amperage the can handle.Stranding is just to change the flexibility of the wire for working in tight electrical enclosures.All 4 gauge wire will handle the same.stranded or not.The wire will have the same performance as typical fancy coloured amp wires as far as noise and suppressiongoes too.Go ahead and use it.Its nice to see people save money where they can.
Old Mar 5, 2007 | 09:11 AM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The biggest problem is the extreem stiffness of that wire, it's going to be impossible to route.
Old Mar 18, 2007 | 09:35 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Not all 4 gage is the same. That wire will have a higher resistance per foot then a higher strand count. It's just not enough of a difference to worry about. It's going to be stiff, but i think the bigger problem would be how it would hold up at the connections over time. A wire that stiff is going to transfer a lot of vibration. This may give you some problems down the road that would have you pulling the wire back out. I would avoid using that stuff. It's great in buildings where vibration isn't a problem.
Caspar
Jun 19, 2016 11:19 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
