what kinda amp do i need
Old Mar 5, 2007 | 03:42 PM
bigjaren13's Avatar
ok i have 2 10 inch mtx subwoofers. i just got a jenson 200 watt 2 channel amplifier for them. would that amp work well for my 2 10's or do i need another amp or what????
Old Apr 4, 2007 | 02:07 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Re: what kinda amp do i need
Is that 200 watts RMS or Max? If it's RMS then just bridge the amp. You do that by hooking your subs posative lead to the amps Left Pos. and the subs negative lead to the amps Right Neg. That will push the holy livin' crap out of them. Turn your gain to about half or so on your amp too, you don't want to fry anything.
Old Apr 4, 2007 | 08:14 PM
89ROCDROPTOP's Avatar
Car: 89IROC conv
Engine: LB9
Axle/Gears: 3.73 posi
If your lookin for a little bit of bass thats fine, but if you want them to pound youll need a little more amp
Old Apr 5, 2007 | 01:50 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
and if you get a bigger amp.. make sure its a mono amp if your going to be running your subs off them
Old Apr 5, 2007 | 10:17 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
you dont HAVE to get a mono amp, even though thats what i use , but just because they are very good, dosent mean you need one. just wanted to point that out.
Old Apr 6, 2007 | 10:10 AM
TheBandit's Avatar
Engine: Poncho 350
well its easier if you dont want to worry about bridging and whatnot.. its easier to get a mono amp imo because you just hook em right up
Old Apr 6, 2007 | 05:52 PM
Iroc_man's Avatar
Car: 87 Iroc
yeah thats true.
Old Apr 7, 2007 | 05:01 AM
SY1100's Avatar
If I were you I would try selling the Jensen amp and getting a punch P550.2 or something similar... Just keep in mind that under powering a sub kills them, so whatever the min. power rating is you generally want to double it to be in the safe range...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
