couple questions
Old Apr 1, 2007 | 10:30 AM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
couple questions
alright im going to buy these speakers(listed below).
I would like to buy a 5 or 6 channel amp so i can possibly add subs in the future, how many watt amp do i want? any sugguestions for an amp
I would like to run all new wire for the speakers instead of using the old stuff(im a newb when it comes to speakers and how to set it up) thanks!
what i need to know
-what size wire to get? for everything
-i know how to "hide it and where to run it" just dont know how to run it, if that makes sense
-is there a kit i can buy for wiring?
JBL 4x6 p6452
Features:
2 Way plated 4x6" Coaxial speakers
Max power handling: 150 watts
RMS power handling: 50 watts
4 ohm impedance
Mounting depth: 2-1/16"
Sensitivity: 89dB
Frequency responce: 75 Hz- 23kHz
Oversized Plus One honeycomb-laminate woofer cone
1" Titanium Tweeter with titanium deposit dome
High-roll butyl rubber surround
Mounting hardware & grilles included
JBL 6x9 p8652
Features:
2 Way 6"x8" / 5"x7" Coaxial speakers
Max power handling: 210 watts
RMS power handling: 75 watts
4 ohm impedance
Mounting depth: 2-1/4"
Sensitivity: 90dB
Frequency responce: 45 Hz- 23kHz
Computer-optimized voice-matched outboard passive crossover
Old Apr 1, 2007 | 11:02 AM
urmomshot77's Avatar
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
Re: couple questions
Well i would recommend 4 gauge wire setup. that will handle just fine for what your doing. Yes kicker and other companys make complete wiring kits for car systems. I would recommend to go with 2 amps. 1 amp dedicated to push your sub (and powerful enough to add an additional sub in the future), and a cheaper 4 channel amp to power your mids,uppper,and tweeters (they dont need a lot of power, 250w or 500w amp max). You will probably need 2 distribution blocks as well. That will let you power both the amps with 1 wire. If you have a local car stereo shop, i would highly recommend you tell them what your looking for, as they can help you alot for what you need. (exspecially wiring diagrams and instructions) Just remember, alot of those places will try to sell you top $$$ stuff that you can usually buy online for MUCH less. So shop smart. I dont know how much you have to spend, but i would buy a high quality mono channel amp for your sub, thats powerfull enough to push another sub when your ready to upgrade. And probably go with something as simple as a crunch amp or sony xplode amp to push the mids/highs/tweeters.
Old Apr 1, 2007 | 11:08 AM
tourville's Avatar
Car: 1991 Camaro RS
thanks, my local shop said to get a 5 channel amp for the expansion of subs later on... i told them i did not want subs as of right now, just the regular interior speakers and an amp
he said 5 channel amp for the set of jbls' i heard em really nice! found em for 100$ cheaper shipped for each pair online already,
just dont know what type of amp to get, dont even know if i will ever put subs in or not, i use my trunk lol
what about this amp for those 4 speakers? http://cgi.ebay.com/KICKER-06-ZX350-...QQcmdZViewItem
Old Apr 1, 2007 | 04:35 PM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
i always use two amps schoche makes a dual amp wire kit so you can run one power wire to two amps so you can mount one amp and power it and if you ever decide to run subs you can wire up the other amp and not have to buy more wire just keep your speaker wire away from power wires and youll be fine as for amps go if your not worried about being able to fade left to right just use a two channel amp for your full range speakers i think it works just fine
Old Apr 2, 2007 | 03:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
5 channel amps are a pain in the *** because when you want to upgrade, you wind up with a semi-useless amp. Since the 5th channel is never powerful enough, you will definately want to upgrade.
Buy a good 50x4 4 channel amp. When you do decide to upgrade to subs, this amp will prove to be very versital. When you initially upgrade, you can take the 2 channels that initially power your 6x9s and use them to power your sub instead. During that time you can use your head unit to power the 6x9s, since they will require very little power once you send your bass to the sub. This will work out well unless you decide that you want it even louder. If you do, then you can buy as powerful of a sub amp as you want, and then just put the 4 channel amp back onto your 4x6s and 6x9s, or double the power to the 4x6s and keep running the 6x9s off your head unit.
Old Apr 3, 2007 | 11:17 AM
tourville's Avatar
Car: 1991 Camaro RS
thanks!
Old Apr 12, 2007 | 06:06 PM
tourville's Avatar
Car: 1991 Camaro RS
i just realized, good thing i did not order the "6x9" speakers, they are not really 6x9, was setting up to order some of the stuff today, as far as 2 way and 3 way speakers go which is better? whats the difference from a 2 way and a 3 way?, im looking at a pair of jbl 6x9's that are 3way speakers, and noticed that the 4x6's im getting are only 2 way
Old Apr 12, 2007 | 06:17 PM
tourville's Avatar
Car: 1991 Camaro RS
also if i go with this amp is it going to be to powerful for the 4x6's that can only handle 50w max rms and it puts out 60w
Kicker EQ boost up to 18db 20hz - 200khz frequency response 250mv - 10v input sensitivity
>95db or better signal to noise ratio
Selectable low pass crossover
Subsonic filter @ 25 hz 12 db per octave
12 DB per octave 50 â?? 200hz adjustable crossover
High pass low pass or all pass
60 Watts x 4 RMS 4 ohms CEA rating
90 Watts x 4 RMS @ 2 ohms
175 Watts RMS x 2 @ 4 ohms
Soft start circuit
Protection circuit
Dimentions:13 1/2"L x 2.1/8"H x 9 -5/8 "W
Old Apr 13, 2007 | 08:24 AM
Jim85IROC's Avatar
Any amp will be too powerful for 4x6s if you don't filter the bass out of them. You can blow up a 4x6 with a head unit if you run it full range.
Likewise, any amp is safe if you just don't over drive the speaker! When things start to get fugly sounding, turn it down. A 50 watt amp is fine for the 4x6s as long as you filter it properly. A 100hz or 120hz high pass is what I would recommend.
Old Apr 13, 2007 | 03:59 PM
tourville's Avatar
Car: 1991 Camaro RS
so with that amp i will be able to filter it correct?, what about the 3 way speakers, should i get my 6x9's with the 3 way or the 2 way? whats the difference
Old Apr 20, 2007 | 11:30 PM
tourville's Avatar
Car: 1991 Camaro RS
im ready to order an amp now.. is this one any good for my application? 50 watts x4 rms @ 2 ohms. its on ebay
http://cgi.ebay.com/Kicker-ZX200-4-4...QQcmdZViewItem
Kicker ZX200.4 4-Channel 200Watt Amplifier
Features :
12 DB per octave 50 – 200hz fixed crossover
35 Watts x 4 RMS 4 ohms CEA rating
50 Watts x 4 RMS @ 2 ohms
100 Watts RMS x 2 @ 4 ohms
Soft start circuit
Protection circuit
Dimentions:16 3/4"L x 2.1/8"H x 9 -5/8 "W
Old Apr 21, 2007 | 08:44 AM
tourville's Avatar
Car: 1991 Camaro RS
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
