how much fiberglass do I need
Old Apr 11, 2007 | 04:59 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
was checking out some of the awesome boxes some of you guys made and I had a question on average how much fiberglass cloth was needed to do the boxes. also where do you get 0.75 ounce mat I guess that is the general concensus of what was used on the first layer. also the 40 oz are the weights per cubic yard? lots of questions also what is v3? I noticed it was mentioned in Gummie's buildup thread I can't find who makes it. I am assuming it is a sealer. here is the thread I am talking about if anyone else wants to check it out.
https://www.thirdgen.org/forums/car-...ghlight=gummie
Thanks in advance
Old Apr 12, 2007 | 01:20 AM
jstoltz's Avatar
Re: how much fiberglass do I need
ttt and bump I want to get the stuff for this this weekend if I can.
Old Apr 12, 2007 | 12:31 PM
jstoltz's Avatar
*bump*
Old Apr 12, 2007 | 01:14 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
well , i dont know at all , and you dont know at all all i can say is , find what you think is enought and order 2x of that heh =) you want think fiberglass for boxes i am sure just like wood maybe 3/4's thick
Old Apr 13, 2007 | 10:14 AM
jstoltz's Avatar
bump
Old Apr 13, 2007 | 11:10 AM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
If you have never done fiberglass work before then you should get these videos. And Custom enclosure projects are not just a couple day projects for the most part. Good luck.
http://www.caraudiohelp.com/how_to_f...fiberglass.htm
Old Apr 13, 2007 | 11:32 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
there one guy thats been building his box for like what 2 years? last i checked , hell even jim's still working on his kicks and stuff and thats taken for ever! (bastard want pair bad =( )
Old Apr 13, 2007 | 12:08 PM
jstoltz's Avatar
I work weekends (12 hrs fri and sat at time and a half) so I have 5 days to work on it a week. seems pretty straight forward doing it but I don't want to mess it up and be out $300 or so.
Old Apr 13, 2007 | 12:33 PM
Car: 91 RS
Engine: 305 TBI
After your first week on your project let us know where you are at.
What size of speakers are you making the enclosure for? Are you going to paint it?, carpet?, vinyl wrap?
Old Apr 13, 2007 | 12:48 PM
jstoltz's Avatar
planning on doing two 12"s nothing special and since it is going in a vert you won't be able to see it so nothing real fancy design wise. I am just going to call up ACC and get matching carpet for it. I am more than likely using Alpine Type X subs. If I actually get started I will do a pictorial on it and list all of the material and how much mat and cloth I end up using. honestly that will more than likely be the hold up because I really don't know how much to get right now and I may try a set of kick panels if I can get the angle right in a decent amount of time.
Old Apr 13, 2007 | 01:03 PM
Car: 91 RS
Engine: 305 TBI
That sounds good. I do stand by those video's that I suggested and posted their website. Very cheap expert info. Highly recommend. Have fun.
Old Apr 13, 2007 | 02:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You'll need a stupid amount of cloth and resin.
For a well sub box, i've used 13 or so yards of cloth, with some mat in there as well, and I might be half as thick as I want (1/4"). I'm not done, had to take a break for winter while I was in school. 3 gallons of resin too. I'm going a little too thick on the resin though. This is .75oz cloth I think, that's the norm. The thicker stuff is not as common, but if you can get it, it'd save you doing as many layers.
Mat is available everywhere, walmart, autoparts stores etc. It's the easy stuff. The cloth is where you can get different weights etc.
And yea, cover it in carpet, it'll hide all your screwups a lot nicer
Old Apr 13, 2007 | 02:28 PM
jstoltz's Avatar
good deal I will probably get 10 yards of the .75 oz stuff and get 10 yards of 40 oz cloth. probably kitty hair too at least 1 gallon and get about 3 gallons of polyester resin. this sound like it might be enough? 1/2" sounds plenty thick enough. also some mdf to brace for the subs. They are pretty heavy.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
