Which 4x6 fit in a 1992 firebird WITHOUT modifications and sound good?
Subject says it all. I am looking for speakers that will fit in the dash of a 1992 formula without heat molding or cutting. I have a Kenwood amp that will be supplying around 25 watts RMS to the dash speakers. Which sound good and fit without issue?
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Re: Which 4x6 fit in a 1992 firebird WITHOUT modifications and sound good?
check out http://www.crutchfield.com/ , outfit your car , and try from there , just DONT BUY FROM THEM!!! god there expencive , check out for a better price
Car: 1991 Pontiac Firebird
Engine: 305 TBI V8
Transmission: Automatic
Jtufts is right. . they have an awsome cataloge system for just about every make and model. .. but they do charge quite a bit. . . . Find what you want, but buy them from a different place.
Car: 1992 trans am tpi 350
Engine: tpi 350
memphis should have a set that will fit.
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
a simple fab thing to do is use a heat gun and use the speaker to push down on the heated plastic , its what i did in my 89 tho people say they did not need to do that with there 89 i had to , why , i have no idea but it worked and my plates fit good now
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Look at some Pioneer speakers. They sound decent and you can't argue with the price.
1 Post
Car: 91 RS
Engine: 350 TBI
There are some Kenwoods that will fit too. That's what I'm going with.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I just threw a set of pioneers into the dash yesterday, only had to drill new holes in the bracket to get them to fit.
Car: 1987 GTA
Transmission: 4L60e
when I did speakers in my 92 Firebird way back when - I originally bought plate speakers (with two cones). These would NOT fit. All you need to do is find a 4x6 speaker with a single cone the length of the speaker. That should fit without issue. The plates are what have problems fitting.
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i have some 4x6 infiniti's up front, i get complements about it.
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Car: 84 camaro z28
it may sound cheap but head up to walmart and buy 2 sony Xplode 4x6 speakers and they fit no problem. since its such small of a speaker all that really counts on them is the tweeter and they sound great for 40 bucks.
1 Post
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
i did the same thing as ricksiroc and have no regrets. honestly they sound great and if you have a nice deck that blocks the bass to them there is no issues with distortion. great bang for your buck imo.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
1992, 1999, 4x6, 92, convertible, firebird, fit, front, modification, modifications, reference, seats, sound, speakers
