guys nees your help on more bump in the convertible
Old Apr 19, 2007 | 08:33 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
ok right now i dont have any bump in the trunk but i wil lbe getting to that later. my first project in this 2 part project is to get better results out of the mids and highs. right now i have pioneer 6x9s um 3 way in the back where the 4x6's used to be on the 89 camaro convertible and i had to use a backing plastic peice to bring out the 6x9. i dont like the 6x9 anymore as it just dosent cut it for any type of bass. i would like to remove the plastic backing or at least trim it down so it dosent stick out so farbut not sure how a 6 1/2 would sound in its place. im thinking a good 4 channel amp will work for the mids and highs but not entirely sure how much. 100watts 200watts? for the second part of this project i would like to install 2 10's or 2 12's in the trunk of the car. Now when the top is down ,and this is pointed at anybody who has a convertible already, will i be able to hear the bass or will the top drown it out? just would like to know your ideas as i already have a 2 channel PPI amp power series but will need a 4 channel amp and i have 10's if you think that will work JL 10w3d4's to be exact. i listen to alot of rock and rap and punk. so i want it to sound good with or without the bass ya know for those times you need to turn off the amp while the cop rolls by lol..anyways lookin for ideas pics anything that will get a geear turning.
Old Apr 27, 2007 | 05:04 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Re: guys nees your help on more bump in the convertible
As far as subs go, I would put a band pass box with 2 10's. Get a 250+ watt rms per channel amp and that would pound pretty darn good. I don't roll in a convertable so I'm not sure about the trunk space. That's where the 2 10's instead of 12's come in. Save some space for you and that type of box will sound good with the type of music you listen to.
Old Apr 28, 2007 | 09:05 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
uhm... dont get a bandpass box.. premade ones are garbage and properly made ones are very hard to make.. either go sealed or ported.. im not sure but it may be a little different when the tops down but they should still bump.. if you want subs that sound good JL's are nice.. but there are better for the money imo.. jl's are very expensive and theres a lot of cheaper subs that are just as good
Old May 1, 2007 | 11:03 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Well I can't help you to much with the mids and highs. I still rock with the stock dash 4x6 and nothing in the rear. lol. But I do have the subs. https://www.thirdgen.org/forums/car-...-12s-vert.html. I built a custom sealed box and put two alpine type-e's and a alpine mrp-350 mono amp. It pushs about 750 watts. And it sure dose give it enough bump to shake the whole car. I listen to mostly Rock, Alternitive and Rap. And about the sound with the top down. I usely do about 80-90mph on the freeway and it still sounds good. You are going to have to crank it up though. And it won't sound as loud as if your stopped. But still sounds good. But if you have the money a would seriously look into getting a setup with some power. Otherwise your top down cruzing will suffer. I plan on stepping it up some more also. Now this all depends on how loud you listin to it. I like to set off car alrams and what not. So I listen to it LOUD. And you may not. so it just depends on how loud you want to go with the top down. If I had this in my IROC with the hatch it would be perfect. Because with the top up I've had to turn it down do to my ears ringing. lol. so in a coupe it would be great. Adam :-)
Old May 2, 2007 | 05:48 PM
TheBandit's Avatar
Engine: Poncho 350
charlie unless you have a high output alt lose the cap
Old May 2, 2007 | 11:53 PM
Why? Just curious. The car seems better with the cap then it did with out. I have had no problem with the alt or battery. I've had it for awhile now and everything works fine even at night with lights on. Adam :-)
Old May 3, 2007 | 03:07 PM
TheBandit's Avatar
Engine: Poncho 350
i beleive it puts more of a load on your alt. a high output alt. or even the big 3 will change things drastically with the charging system
Old Feb 15, 2008 | 01:02 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
I HAVE 2 JL AUDIO 12W3'S AND LOOKING FOR SOMETHING WITH MORE POWER, THINKING ABOUT GOING WITH SOME KICKER 12L7'S WHAT ARE SOME OTHER SUBS THAT DON'T NEED MUCH AIR SPACE AND NOT TO HIGH BUT HIT GOOD, I CAN GET 2 L7'S FOR ABOUT 350 A PAIR
Old Feb 15, 2008 | 04:20 PM
IROCc_916's Avatar
Car: 86' I ROC
Axle/Gears: 373 rear disc
hmm. what charlies sayin does make sense. but i have two type R alpine 12's that i had hooked up to a 1200 fosgate amp that i had and it dimmed my lights big time!. then when i put my cap on it stopped the dimming. i put a 19 volt cap on tho. i've had it on for about 2 years now.. even tho the name brands dont match they work pretty good together. i get a real nice back message
Old Feb 15, 2008 | 05:07 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
IROCc_916, i notice you where a newbee and wanted to say welcome to 3gen
Old Feb 15, 2008 | 05:17 PM
IROCc_916's Avatar
Car: 86' I ROC
thanks! i noticed all these wiser older men who already been there and done it. So with the knowledge there spreading its helps us rookies a lot. theres no better site then this one.
1992 Trans Am
May 10, 2023 07:19 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Jake_92RS
Aug 17, 2015 09:42 AM
Street Lethal
Aug 14, 2015 08:25 PM
gwade12
Aug 8, 2015 08:17 AM
