Massive Static at times with Stock Radio & Speakers
Old Jun 25, 2007 | 12:10 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
My 91 RS has the stock AM/FM Stereo w/cassette and four speakers.
About half of the time when I turn the radio on, there is a nasty static sound that drowns out the everything else. It doesn't seem to come from a specific speaker. It's across all stations. Sometimes it's very loud and sometimes it's more moderate. Turning the radio on/off doesn't have any effect.
I would appreciate suggestions on what to check.
Old Jun 25, 2007 | 07:49 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Massive Static at times with Stock Radio & Speakers
Has this been a constant problem or one that just started?Loose grounds/harness connections can cause electrical interference,have you modified the ignition system also it could be the volume control.The contacts in them sometimes get dust/dirt in them.Use a good electrical contact cleaner and pray down inside the shaft.
Old Jun 26, 2007 | 10:55 AM
All the electrial stuff is stock.
It started a few months ago and has gotten worse.
Good idea about checking all the grounds and the contact spray.
Old Jun 26, 2007 | 03:48 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
I would go over the entire system's length of wires from component to component. Hit all connections with contact cleaner (speaker connections, stereo controls, the connectors to the tape deck) and make sure that the wires aren't frayed anywhere.
Old Jun 26, 2007 | 04:32 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
the stereo system in my moms z28 started acting up, a few weeks later the coil went out. hows your ignition system look?
Old Jun 27, 2007 | 09:59 AM
Coil's been in there for around four years. I've not looked at it in a long time. That's another good idea. I'll check that too.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
