Sub Box and Amp Build Pics
Old Jul 5, 2007 | 12:29 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've been meaning to post these for some time. I've posted the finished product in various threads, but neglected to show some of the progress. I replaced my old sub box which housed 2 JL 10W6 woofers and had installed a single Memphis 15-M3MOJO12 12" woofer capable of handling 2000 watts (1000 continuous). I also relocated my amp from the cargo deck behind the seat to the well with the sub.
My old setup
New woofer
Beginnings of the box with the woofer test fitted.
Old Jul 5, 2007 | 12:38 AM
Al Hasse's Avatar
Re: Sub Box and Amp Build Pics
More...
Fiberglassing the bottom half.
Woofer ready for install
Ready to relocate the amp, crossovers will be located under the amp
System complete
Old Jul 5, 2007 | 12:52 AM
Al Hasse's Avatar
To finish up, I had a cover made from expanded metal and covered with acoustic carpet to protect the amp and sub from any cargo.
The underside of the cover
Finished product
Old Jul 5, 2007 | 01:04 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
That looks super clean and stelth. Great job.
Old Jul 5, 2007 | 12:16 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
very nice install very clean.. but you don't need a capacitor
Old Jul 5, 2007 | 03:45 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I know he doesn't need one, but it all came together so perfectly. It's gatta stay there now.
You have renewed my interest in getting a sub.
Old Jul 5, 2007 | 04:34 PM
Al Hasse's Avatar
Thanks, yeah I know I don't need the cap, but I got it when I didn't know any better and didn't see a reason to leave it out when relocating the amp. It's almost useless since I use a second battery to power the system.
Here...
Old Jul 5, 2007 | 10:25 PM
TheBandit's Avatar
Engine: Poncho 350
yeah we all do stuff when we dont know any better, then realize when we do, that it wasnt a geat idea, but never the less the setup is awesome, and having that second batt in the side there is awesome
Old Jul 6, 2007 | 04:31 AM
Axle/Gears: 3.27 BW
Okay, you've made me want a big sub. Do you have a file with the plans for cutting the board? Possible dimensions on the sub section? Is the amp sitting on foam, or something?
I've decided that I pretty much want to emulate this setup, minus the cap and the spare battery.
Old Jul 6, 2007 | 02:59 PM
Al Hasse's Avatar
There were no real "plans" for the box, pretty much measure and cut as you go while ensuring the recommended cubic ft volume for the sub. My installer did use as a guideline of sorts, the plans for a well enclosure up in the sticky section of the forum, only he used fiberglass for the bottom half.
This one took him a good week or so to build (thankfully I have another car) along with other jobs at the shop. The size of the sub (it weighs in at 36 lbs!!) and the dimensions of the amp added a degree of difficulty. The plastic trim over the spare tire had to be trimmed off on the bottom to allow wiring to go through. Also a possible mistake in measurement doesn't allow the enclosure to be removed without first removing the pull-down motor (theft deterrent??).
The amp itself is mounted so the top sits flush with the sub surround, then a piece of hardboard (like pegboard without the holes) with the openings cut out was used to create the "flush" mount appearance. No foam, there is a lot of free air space under the hardboard. In effect, the carpet covered hardboard is just a facade to make it look pretty.
Old Jul 6, 2007 | 08:48 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
can you still access the spare tire?
Old Jul 6, 2007 | 09:38 PM
Al Hasse's Avatar
Yes I can still access the spare tire, but it's a tight fit with some of the wires. I may take it out entirely and let my roadside assistance coverage take care of any difficulties in that area.
Old Jul 7, 2007 | 05:25 AM
Axle/Gears: 3.27 BW
How much did the boxing project run? With the glass work I can imagine a bit more than a normal MDF enclosure.
Old Jul 7, 2007 | 11:14 AM
Al Hasse's Avatar
I can't say how much for sure since I bought the woofer at the same time, then add woofer install, amp install (relocation),etc. Woofer was close to $450 which was almost half of the total price. Best guess is between $350 and $400 for the enclosure.
Old Nov 5, 2007 | 10:57 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Woofer specs?
Old Nov 5, 2007 | 12:46 PM
Axle/Gears: 3.27 BW
SPECIFICATIONS
M3MOJO12
Continuous Power Handling
1000 watts
Maximum Power Handling
2000 watts
Sensitivity (2.83 volts)
89.89 dB
Magnet Size
228 oz.
Mounting Depth
8"
Voice Coil Configuration
Dual 2 ohms
M3MOJO
The baddest bass. Originally designed for SPL competition,
the Mojo sub has more than proven itself in the lanes. Couple it with one of our Mojo amps and you can create enough sound pressure to blow the gasket out of a windshield. If you've got Mojo, everyone will know it.
Old Aug 13, 2008 | 08:24 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
That's awsome! Love the stealth look!
Old Aug 16, 2008 | 04:53 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I like the install. Looks really clean!
Old Aug 16, 2008 | 07:19 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
yah man that looks great, does it rattle or anything or does it sound good and tight?
Old Aug 16, 2008 | 01:58 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
beautiful setup man, i love how clean it looks, and how little cargo space it takes up.
Im planning to do something similair with a 10" kicker L7
Old Aug 17, 2008 | 06:31 PM
Al Hasse's Avatar
Very little rattles, if any. The car was dynamatted prior to this install, the license plate frame also got a little dynamat treatment.
Old Jan 1, 2009 | 09:27 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Here...
hey thats a sweet setup but i was wondering how u made the system run off a seprate battery and still have that battery charged
Old Jan 1, 2009 | 09:59 PM
Al Hasse's Avatar
I used a diode isolator up front. The alternator charge wire connects to the isolator, as do both batteries. The alternator will charge each battery as needed and the isolator keeps eah battery separate from each other.
Old Jan 2, 2009 | 08:28 PM
87transGTA's Avatar
Car: 87 GTA
thanks alot that pic really helps
Old Mar 3, 2009 | 07:06 AM
Car: 1971 Camaro
What amp is that? Is it a six channel amp?
Old Mar 3, 2009 | 07:22 AM
Al Hasse's Avatar
It's an older Memphis Belle 5 channel amp. Memphis now calls it the Hybrid, it's a Class D amp for the sub channel and a Class AB amp for the other 4 channels.
http://www.memphiscaraudio.com/produ...***-amplifier/
Old Mar 5, 2009 | 07:43 AM
Car: 1971 Camaro
Hey where did you buy the expanded metal from?
Old Mar 5, 2009 | 11:04 AM
Al Hasse's Avatar
I believe my installer acquired it from a welding supply shop, where they have various gauges of sheet stock. I wanted to call it perforated metal, but expanded is correct because it's made by cutting slits in the metal, then pulling the metal to "expand" the slits into the diamond shaped holes.
Old Mar 5, 2009 | 11:18 AM
Car: 1971 Camaro
Great, I'll check there, I wish I could find something like that in aluminum.
Thanks again
Old Mar 5, 2009 | 11:25 AM
87350IROC's Avatar
Car: 87' IROC
Al,
I'm looking at making smaller box to fit a single 12", kind of like yours that isn't flush with the gas tank hump. I see you mentioned this box cannot be removed intact, at least without removing the hatch motor. So how did you get the box in? Did you have to remove the hatch motor to get the box in?
Old Mar 5, 2009 | 11:48 AM
Al Hasse's Avatar
If memory serves, the fiberglass was laid in the bottom to get the form, then the framework support was constructed. After assembling the frame and fiberlass, the assembly wouldn't drop into the well without removing the pulldoen motor. I'm sure a few well placed cuts around the motor could remedy the situation, but it works good and I can still remove the trim to access the tail lights.
Old Aug 12, 2009 | 02:19 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
sick build man, giving me ideas.
Old Aug 14, 2009 | 11:32 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
not exactly the most custom thing in the world but it does a good job
Old Aug 18, 2009 | 12:19 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
I wanted to mount my amps there too but....isnt the gas tank right under there?
Old Aug 18, 2009 | 01:39 PM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Just a note on isolators. There is a voltage drop across them which can result in undercharging of your batteries. An internally regulated alternator won't be able to detect the state of charge of your batteries. A better alternative to an isolator is an automatic charging relay (ACR) like this one from Blue Sea systems.
http://bluesea.com/category/2/productline/overview/387
I had a problem with dual battery banks (starting/house loads) on my boat. I was using an isolator. After killing two sets of batteries from chronic undercharging I rewired the entire boat and put in the ACR. No more problem.
Old Aug 18, 2009 | 02:17 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Good thread. Al Hasse, good job on your setup.
Jay
Old Aug 18, 2009 | 10:18 PM
Al Hasse's Avatar
Thanks for the info. Yes, there is a voltage drop across a diode isolator, just the way they work. I've also been looking into another concept when and if I ever run into problems. Hellroaring Technologies makes a nice isolator/combiner for this type of application, among others.
http://www.hellroaring.com/audio.php
This setup has been going strong for about 3 different sound systems I've had in the car over the last 8-10 years.
Old Aug 20, 2009 | 02:08 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
just wanted to say nice job to the OP. The cover/protector is a great idea and keeps the goodies out of sight from those prying eyes....
Old Aug 21, 2009 | 11:01 AM
firebird310's Avatar
Car: 89 FORMULA 350
Axle/Gears: 327
I THOUGHT YOU INSTALLED THAT AL HASSE, ANYONE CAN PAY SOMEBODY.... IT DOES LOOK GREAT.
Old Aug 27, 2009 | 12:38 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Can you still blare your music with the preforated metal cover down? or does it get all distorted?
Old Aug 27, 2009 | 02:38 PM
Al Hasse's Avatar
I can. The cover is acousically transparent, like any speaker grille. Even if it wasn't, it wouldn't matter much with bass frequencies, they'll penetrate almost anything.
Old Jan 30, 2011 | 09:22 PM
  #42
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Sorry to resurect this from the past but this is the cleanest box / stereo set up ive ever seen in a 3rd gen. WOW is all I can say
Old Jan 31, 2011 | 10:46 PM
  #43
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
NICE BUILD.
Old Feb 1, 2011 | 12:44 AM
  #44
polarshift's Avatar
Car: 88 Z28 Iroc-z
Engine: LB9 tpi
Axle/Gears: 2:73 lsd
Cool, here's mine...well, in mock up anyhow.
Old Feb 15, 2011 | 03:23 PM
  #45
TheDarkMinister's Avatar
Car: 88 Trans Am..
Engine: Hmm... 350? The guy told me
Transmission: 5 speed
(after jizzing my pants)....
Old Mar 24, 2011 | 10:40 PM
  #46
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
i love that setup i wish there was some dimensions for the box i have two p2s i want to put in like that.
Old Mar 25, 2011 | 04:04 PM
  #47
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Yea that def. is a rediculously clean install!
Old Sep 30, 2011 | 09:31 PM
  #48
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
so has anyone had any issues with the gas tank or anything when mounting amps or subs on the flat deck area? will sheet metal screws be enough or is there a need for a nut bolt washer type set up
Old Oct 1, 2011 | 11:37 AM
  #49
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the gas tank is under the hump area not under the well area. if youre mouting anything on top of the hump, be sure to use screws just long enough to go through what youre mounting and just barely through the sheet metal. use long *** screws and you risk putting a screw in the tank...
Old Oct 1, 2011 | 08:58 PM
  #50
Car: 89 IROC
Why not use an amp rack.
