subwoofer enclosure
Old Jul 20, 2007 | 08:07 PM
shootryan's Avatar
Car: 85 Chevy Camaro
Engine: 383/holley carb/edelbrok intake
subwoofer enclosure
i recently built an inclosure for my 2 12" kicker comps. it sounds great when i have it at a low level, but when i turn them up there is a loud popping noise. does anyone have any ideas what might be causing this? let me know please. and thanks in advance
Old Jul 20, 2007 | 10:13 PM
Big E's Avatar
Re: subwoofer enclosure
Sounds like you might be clipping the signal. How are the gains on your amp set? Are they cranked all the way up? If so, turn them all the way down, then SLOWLY turn them up until the music sounds good. One word of advise though; NEVER use the Bass Boost function...it can easily cause clipping (distortion) which causes your subwoofers to overheat and be permanently damaged.
Old Jul 21, 2007 | 08:13 PM
shootryan's Avatar
i tried tuning the gains today and no luck. i basically had to turn them completly off to get it to stop popping... i could barely hear the subs when down that far. then i turned them up a little and i had the same results... being the poping noise... any other suggestions
Old Jul 22, 2007 | 06:36 AM
Big E's Avatar
What amp are you running these off? Also, at what ohms?
Old Jul 22, 2007 | 09:37 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Are ur subs dvc's? Check your cones and your wiring to see if they are wired correctly. Also check and make sure your enclosure is air tight, all around.
Old Jul 25, 2007 | 09:05 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
if you run the wires from your head to your amp on the same side as the main power feed, you can get some noise but i dont think it would be poping probably more like static. just another thing to keep in mind.
Old Jul 26, 2007 | 01:53 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I also just built a sub box for my 12" Kicker Comps. I'm running a 1000w amp for both. I haven't had a problem. Just go back and check your connections, make sure everything is grounded correctly and that the box is air tight. I used a hot glue gun to seal all the seams and edges of the box... Good luck...
Old Jul 26, 2007 | 03:37 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
i always used phenoseal caulking to seal mine.. what is the vc config on the subs? and what amp do you have? what is it wired too?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
84 TA NV
Sep 6, 2015 08:02 PM
tc7761
Aug 30, 2015 09:45 AM
Chuck84TA
Aug 27, 2015 11:14 AM
Jim85IROC
Nov 7, 2001 07:05 AM
