will this fix my problem?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: will this fix my problem?
the woofer is blown.. to me it is trashed.. you can glue it together and it will still "work" but it wont have as good of quality and most likely will separate again... is there just a little part that is separating, or is the whole cone separating?
it is just a little part that is seperating, maybe an inch long
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
That should just be a dust shield. The only issue would be it vibrating against the woofer cone. You should be able to glue it and as long as it holds everything else should be normal.
ok cool. so would it be better to take it all the way off? or just glue it down?
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
I'd glue it down, it's only purpose is to keep dust out of the coil and what not. You don't want build up down there and things touching from a dust blanket.
theshackle
Mar 5, 2017 06:37 PM
