Amp overheating need help
Old Aug 8, 2007 | 03:22 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
Axle/Gears: Richmond 3.73 and Aurburn diff
i just bought a set of polk 4x6 and a set of polk 6x9 here are the links to those speakers
http://www.circuitcity.com/ssm/Polk-...oductDetail.do
And I also bought this mtx thunder amplifier for the speakers because the guys there told this would be enough to power the speakers
http://www.circuitcity.com/ssm/MTX-4...oductDetail.do
well lately it has been overheating and shutting down on me...I replaced the ground wire to larger gauge and it still does and it seems like its doing it more and more is my amp to small or is there something that im doing wrong with the wiring...ill post pics later
Old Aug 8, 2007 | 03:46 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
Re: Amp overheating need help
I know the wiring is a mess but my sub box covers it all up....my gain is not even set to half way...im not gonna lie im new at this sound system stuff this was the first car that i have done im not sure what to do about the band pass filter...to be quite honest i dont even know what that means i just have all of them set to off
Old Aug 8, 2007 | 04:08 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
you need to wire the amp for ohms also.
load the amp for the rated ohms and it will not overheat and kick off.
Old Aug 8, 2007 | 05:28 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
how do i do that?
Old Aug 9, 2007 | 08:54 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
In my opinon heres how u do that... resistance is measured in Ohms in the electrical world, aka the work needed to done. your speakers are the resistance and so should all be the same ohm rating. Most amps are designated with power output levels for 2 and 4 ohms. More resistance means less power, so if your looking for power use speakers with the lowest possible ohm rating.
Derek
Old Aug 9, 2007 | 09:39 PM
1990Wolfman's Avatar
Car: '90 Chvy T-tp Rs wth Z28 frntclip
Engine: 3.1 atm
Transmission: Crap atm
Axle/Gears: see tranny
also having them covered will keep them from breathing properly..
just my 2 cents
Old Aug 9, 2007 | 11:10 PM
5hOeater's Avatar
Car: IROC
how many watts?..is the amp and are you using them for 4 speakers?..shouldnt be overheating..you might need a bigger amp.. personally i like hifonics.. they never let me down.. anyways..if you using for highs... u need to turn off low bandpass and high pass on.. and control how much u want it.. have the radio on so u ca hear it as u adjust.. but if its overheating..its becuz something is no right.. maybe a short.. or amp is too small.. check the wires
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
