bad ground?
Old Aug 20, 2007 | 03:33 PM
thomeygun1's Avatar
Car: 91 TA
bad ground?
i just recently put subs and an amp in my 91 ta. as soon as i turn the stereo on the subs make a constant thumping sound is this a bad ground or a bad connection somewhere?? any help is appreciated thanx
Old Aug 20, 2007 | 10:14 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: bad ground?
Some call it motor boating and it's caused by a high resistance in the power supply wires, ground or B+. Check at the battery, fuse holder, and ground.
Old Sep 17, 2007 | 11:11 AM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
Re: bad ground?
the rcas on the back of ur radio are blown or stopped working whatever u want to call it that happened to me and i just replaced my headunit and it fixed the problem try switching it out with a different one. see if that fixes it.
Old Sep 17, 2007 | 08:08 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: bad ground?
either the rcas are bad or your getting road noise.. did you run your rcas on the same side of the car as your power wire?
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
TheTraut88
Sep 11, 2015 05:16 AM
Gunsbee
Sep 7, 2015 07:10 PM
Amillionoh7
Sep 5, 2015 11:44 PM
