Power antenna.
Old Sep 13, 2007 | 01:40 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
Power antenna.
All,
I have a 91 z28, that didnt come with a power antenna. I would like to add one, but after researching the factory ones going for 120.00+ i think i could spend my money better elsewhere.
My question is simply this, is there an aftermarket power antenna that is out there that is cheaper than the factory, say 35-45 bucks, that will work, without having to cut the subframe of the car under the fender and without any real modification?
The factory power antenna has a longer shaft than the standard one we get from advance, thus using the one from advance you have to cut a lot of the sub framing away from under the fender just to get it to work.. I want to not have to do that. In fact, I'd prefer to not cut anything, but i just cant bring myself to spend 120.00 + for.
Thoughts? Experiences?
Thanks.
-Steve
Old Sep 13, 2007 | 02:08 AM
FAST91RS-TT's Avatar
Re: Power antenna.
not really. i work at a stereo shop, most of the ones that we sell we get for around 75-80 for the good ones. the cheaper ones wont last. sometimes you can find ones at a junkyard from a newer honda or something, and make it work.
Old Sep 14, 2007 | 04:22 AM
Re: Power antenna.
I was afraid of that. Ive put one of those generic antennas in a GTA before, but i had to cut a crapload out from the inner fender subframe, and i really dont want to have to do that agian. I was hoping that there was a aftermarket antenna with a long shaft, for apps like this.. shame.
Old Sep 14, 2007 | 07:56 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Power antenna.
As Fast91RS stated those cheaper power antennas don't hold up well.My '83 Z28 came with a power antenna that wasn't working when I got her(missing extension shaft and the motor was shorted).I got lucky and another member(DavesIROC of ThirdGeneration USA)had a good used one in stock.But before I bought this one I had bought a couple different ones to try.The rear mount antenna from a '88-'91 Bonneville/88/Lesabre is very close.But in the long run it was better to find a good used F-Body antenna or the universal version you can buy from Modern Day(this is what's also available from GM).
Old Sep 16, 2007 | 02:48 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Power antenna.
Here is what I did to remedy the inner fender subframe problem. I took a piece of pvc tube and put it on the tip/top of the antenna. I only put enough to "make up the difference" of the tip and the hole in the fender. Once the antenna was bolted in, I made sure the pvc tube was bolted solid in place (so it wouldn't move around) and thats it. So when I set my headunit to radio, the antenna raises up perfectly every time. Honestly, the only reason I installed an antenna is to go to the Drive-In (Big Mo)
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
