Custom Box Question
Old Sep 24, 2007 | 05:13 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Custom Box Question
I want to make a sealed box to hold 2 10" subs in the back of my car. The only problem is, I want to make the box so it fits in the lower part of the rear well. It seems like 10's would fit back there, but would there be enough airspace for 2 sealed 10's? I hope so because it would be an easier box to make than the 2 12" box that everyone has, and I could put the T-tops where they always go. Also I would be able to store the amp on the little ledge on the right side of the well.
Also, if someone has ever done this before, please post a pic for me to see! Thanks.
Old Sep 24, 2007 | 05:21 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Custom Box Question
https://www.thirdgen.org/forums/car-...l-sub-box.html
Old Sep 24, 2007 | 05:46 PM
Engine: LO3
I read that thread, but it is for a full size box. My question is about making a box just for the bottom of the well.
Old Sep 24, 2007 | 06:01 PM
Stephen's Avatar
Car: 87 GTA
Just make the wall dimensions shorter. I haven't calculated the resulting space, but my guess is, it would be good for 1 1/2 10" subs. In other words, a bit more than needed for one 10", not enough for two 10".
As for too much space, that would a simple thing take care of.
Old Sep 24, 2007 | 09:05 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I had one made similar to what you want to do for a single 12" sub requiring 1.5 cf volume. It's made mostly of fiberglass and sits just a little higher than the aforementioned shelf. The sub sits to the left side so there is room for my amp over the rest of the box. The box takes up about 80% of the space in the well, so there is some empty space on the right side. This single sub is much louder and hits harder than the pair of JL 10W6 10" I had before.
The box and its framework
After it was all finished, the amp and sub were flushed with a piece of hard board surround covered with carpet, then I had a cover made from expanded metal and covered that with acoustic carpet. I've posted these before, but here's the finished product.
Old Sep 24, 2007 | 11:13 PM
Engine: LO3
Thanks. Here is the amp I have, and I was thinking of 2 kicker CVR 10."
http://www.sonicelectronix.com/item_...16-MC500D.html
Another question, if I wanted to do a single sub, would it work to run each voice coil off its own channel? I ask because my amp is a 2 channel non-bridgable. So thats why I was looking at two cheap 10" subs.
[edit] looks like I was wrong. The amp is a mono block amp. But it has hookups like a 2 channel amp? I mean, it has 2 (+) connections, and 2 (-) connections. Are you supposed to run one a seperate wire to each voice coil?
Old Sep 25, 2007 | 01:16 AM
Al Hasse's Avatar
If the sub you want to run is a dual 4-ohm voice coil, you will probably have no problem bridging the amp as it is 2-ohm stable (I would check the specs). A dual 2-ohm woofer like mine would have to have each voice coil connected to its own channel, unless you connect the voice coils in series to present a 4-ohm load. That's a nice amp you have BTW, mine is an older model of the Memphis Belle.
Old Sep 25, 2007 | 07:52 AM
Engine: LO3
Yeah, then I will probably do a single woofer. I really wanted to be louder than my buddy's 3000GT with 2 12" infinity, and a 1000W sony amp. But I guess that isnt gonna happen with a little 500W amp that I have anyway.
Another thing I was thinking is, is it possible at all to run 2 speakers off a mono amp? I mean, since the amp is 2 ohm stable, what if I got 2 DVC 4ohm speakers, and wired them in parallel to present a 2ohm load, then ran each speaker to its own (+) and (-) channel?
Also, I only paid 40 for the amp. Got it on the street. The guy I got it off of was running a single 12 in his S-10 and it seemed to bump pretty good for 500W.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fast355
Dec 2, 2016 06:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
