Amp for subs
Old Oct 3, 2007 | 07:27 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Amp for subs
I got a few question on what amp to get for subs and stuff. Currently I am running a 2 channel 600 watt amp to my back 6 x 9 speakers. I took out my front speakers bc they were being overdriven after i installed the amp. So instead of buying plaate speakers and amping those too i decided to throw 2 10 inch subs in the back.
Now heres the questions. How many watts should an amp have to run two 10 inch subs. And also should I get a 4 channel or a 2 channel. Since im already using the rca jacks on my headunit how cant i connect the new amp to my system?
Thanks for answering my dumb questions lol
Steven
Old Oct 3, 2007 | 10:07 PM
stagefright4's Avatar
Car: 1992 trans am tpi 350
Engine: tpi 350
Re: Amp for subs
it depends on the subs every type of sub has a different power rating (rms and peak i believe). if you can give us the brand and model we can get you an answer
Old Oct 3, 2007 | 10:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
Im thinking 2 of these guys http://www.cardomain.com/item/POWPW212M 500 w rms and 1200 w peak. planning on putting them in a hatch custom sub box, either make my own or buy one
Old Oct 4, 2007 | 07:21 AM
cdoyle's Avatar
Re: Amp for subs
Those look to have a power rating of 500w RMS (that is the number to look at, ignore peak or max)
So look for amp who's output is similar.
If you are looking for an additional amp, that is going to be used just for the subs try and find a monoblock class D amp. More efficient then 2 of 4 channel amps, for running subs.
To add additional RCA connectors, they make Y splitters you can put at the end of your 1 set of RCA.
Old Oct 4, 2007 | 12:29 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
Ok thanks. Now when I get a splitter for the rca connections I can still control the cutoff frequency for the subs right? oh yea, and since ill be running two subs to i need to look for an amp thats output is about 500w or 1000w if i run both off of it?
Old Oct 8, 2007 | 12:32 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
anyone?
Old Oct 11, 2007 | 05:25 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: Amp for subs
your going to want an amp that puts out 1000.. maybe 1100 or 1200 and keep the gain a little turned down so you dont clip the amp
Old Oct 11, 2007 | 05:52 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Amp for subs
exactly you want more amp than sub. you clip the signal and it goes flat. Then you blow the voice coils in your speakers. I had two 350 watt woofers and put in a 800 watt amp to support it. it's kinda like an engine, ya you make power up high but you don't want to push it like that all the time. same with an amp.
Old Oct 12, 2007 | 11:46 AM
TheBandit's Avatar
Engine: Poncho 350
Re: Amp for subs
just remember to keep that gain turned down a little bit
Old Oct 12, 2007 | 12:39 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
Alright just bough infinity and and 2 infinity subs, thanks. I alss bought a cross over so I can sscrew araound with that alttiel. So I go one last question. Since Ill be running two amps could I just jump the power from the existing amp to the new one? Im running 4 ga wire to the existing amp with an inline fuse. I researched it a little but all I found was a terminal block thast used when you need to change from one gauge to the other. Whats the best way to do this?
Old Oct 12, 2007 | 01:16 PM
ryan91rs's Avatar
Transmission: 4L60
Re: Amp for subs
get a block that has one in and two out. best way or the first amp would take most of the juice leaving the second low on power
Old Oct 12, 2007 | 02:45 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
should i put a bigger fuse in there now that im running two?
Old Oct 16, 2007 | 12:38 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
Anyone know if a store where I cna get a terbinal block thast 1 in and two out? My stuff is coming in today and I wanted to find a place I can buy one from so I dont need to wait anohter 4 days to ship it.
Old Oct 17, 2007 | 01:11 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Amp for subs
Walmart sells cheap distrubution blocks. However, I have jumped the power from one amp to another with good results. But it was 4ga direct to the 960W 4-channel, then 8ga from the 4-channel to the 300W mono amp. So it went logically.
Either way, I dont quite comprehend how one amp will rob another of power depending on the wiring. If they both have a good solid connection it should work. But a distribution block is safer and easier unless you are really on the cheep.
Old Oct 17, 2007 | 07:30 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Amp for subs
Yep I stoped by walmart and got a 4 gauge to 8 gauge dual out and some 8 gauge cable. Also got a set of rca connectors for the output of the cross over I bought. Thanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
