Tips on wiring my amp!
Old Oct 6, 2007 | 12:18 AM
Kevinn's Avatar
Car: 1992 Z-28 25th Ann Edition.
Engine: 5.7 TPI
Hey guys, So I got my subs all hooked up and put into my hatch box.
All I have left to do is run my power and ground cables.
I need some tips on where to run my power cord to, any idea's?
I also need to know where there is a good place to run a ground cable to, any idea's?
Thanks guys,
Kevin.
*Note* I have a 1992 Z-28, I'm running two 12' MA Audio Subs, and a MA Audio HK amp, hope this information helps.
Old Oct 6, 2007 | 06:13 AM
cdoyle's Avatar
Re: Tips on wiring my amp!
A nice FAQ on how to install an ampl.
http://www.caraudiocentral.net/forum...2602#post72602
Old Oct 6, 2007 | 09:46 AM
Kevinn's Avatar
Engine: 5.7 TPI
I just need tips on where there are good places to do these things on my camaro, ive installed several systems before, but this seems to be a more difficult task.
Old Oct 6, 2007 | 09:53 AM
cdoyle's Avatar
For running the power wire, depending on the size of the wire you used. You may be able to run it through an existing grommet. Or if your using too big of wire to make it fit, you can drill a hole and use a grommet and seal it up good after you get the wire through.
For the ground, that depends on where you're mounting the amp. Basically you just want to keep the ground wire short, and connect it to a clean piece of metal on the car.
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ZsTransAm
Aug 11, 2015 07:30 PM
