DVD in dash Install question
Old Oct 31, 2007 | 11:28 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Well I got a good deal on an in dash DVD player so I got it and had it installed. Looks great and plays great. My son has the same model a Valar - ITS-701W except his is not touch screen like mine. Any way after getting it home I notice that they have child proofed the unit and it will only play DVD's if the emergency brake is on. There is a (pink) wire that runs out the back of the unit to the emergency brake hand and once you move it then you can see the pic. I probably could drive with it like this because at just before the first notch on the e-brake the pic comes on. My wife claims she smelled the emergency brake but I didn't. She was just paranoid I thing but don't tell her.
But is there a way to by pass this feature. My son has his on all of the time but he is away at college so I can't see how they did his. I tried cutting the pink wire but all I got was audio and no video. Tomorrow I will take it to a small shop by my house to see what they can do but I would prefer to solve this in my own garage at home. Any thoughts or help would be appreciated.
Old Oct 31, 2007 | 11:51 PM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Re: DVD in dash Install question
Your pink wire may just be a ground wire. Usually what they do for these types of units is force you to put the e-brake on because when that is on there is a ground created and thats how you get the light on your dashboard. Try connecting that pink wire to a constant ground and see if it works for you.
I personally have an old Pioneer in dash that had a wire which was supposed to be connected to the ebrake and all I did with that was ground the wire and it works great!!
Chris
Old Nov 1, 2007 | 06:00 AM
Axle/Gears: Posi
Okay thanks...I will try it in the morning.
Old Nov 1, 2007 | 08:13 AM
rv34's Avatar
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Axle/Gears: 3.70 9 bolt
It is a ground. I have done it before, but some headunits need a switch put in in that pink wire, to reset the circuit.
Old Nov 1, 2007 | 10:38 AM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
That is what a TR6 is for! Like my Alpine needs like power with foot brake then parking then 2 more foot. the TR6 can do all that is a second! But on older pioneers and lower line sceen it is usually just ground the parking wire. If it needs to be reset before a movie I would do a TR6.
Old Nov 2, 2007 | 01:59 AM
Axle/Gears: Posi
I grounded and it works fine now. Thanks everyone.
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
