No rear speakers in 89 IROC?
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Hey guys I was just about to put my new speakers into my new IROC, so i took off the panels where the 6x9's usually are, and found nothing, an empty hole...? i was like wtf is goin on. i do not know if there are dash speakers as i didnt take a closer look but for sure all i know about are the bose AC delco kick panels by your feet. any help would be appreciated guys
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: No rear speakers in 89 IROC?
Mine was the same way except I had speakers in the vary back in the lid that covers the storage well.
any suggestions? i want to mount (2) 6x9's in the panels and put (2) 4x6's in the dash... however, is there even a place for them or what please help
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
u have to fine a camaro/firebird that didnt came with bose system and get the metal adapters out.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Do you have the mounting brackets!? I believe i have some if interested. Not sure of your confusion, is there wires going to those holes where the 6x9's belong?
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
their are two types of mounting brakets that i have found out one is a full circal and the other is a " u" shape what is the difference between the two?
hey 84red ta which ones you got? might wana get em from you if the other dude does not
i got about 5 sets, lol, they are fully oval shaped, no U shape, never seen those. If your interested PM me
there aren't any wiring to the holes, and another question, my left bose kick panel works but the right doesnt. o and im gonna pm u about those brackets, and are they hard to get in? i also would need some help from u guys about how to wire them into the headunit, or perhaps my amp i have for the subs. thanks guys im new to all this
they aren't hard to get in at all...i'm assuming GM used all the same stamped metal to put these cars together, you've got the basics, just not the filler bracket to mount the speaker. Nothing hard, if i've got 4 holes to mount this bracket then good, if not you may have to drill four holes (drill one corner, install screw and do opposite corner so you don't end up accidentally drilling it wrong) other than that, your going to want to hook them up to the rear i would assume, i don'tk now how the bose system is set up. If you guys can fill me in on where the speakers are located and what kind they are (tweeter - highs ; mid range - regular mid sound ; subs - low, deep sound) i might be able to let you know where you should wire in unless someone else taps into this thread first that has experience with bose cars (i do car audio, i have yet to get a bose f-body) Other than that if one of you two can get me a picture of the back with the sail panel speaker grill off i can further instruct you guys on what needs to be done.
ok thanks, ill be doing it tomorrow after school, so ill get some pics up as well. o and 84ta, ill highly consider that deal unless i can find some at the junkyard this weekend. thanks
no problem, i've taken apart an '84 berlinetta, '86 berlinetta, '87 bird, '88 RS, and an '88 Bird, so if you need any little tiny things i most likely have them.
db057
Aug 11, 2015 10:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
