where to mount amp?
Old Dec 18, 2007 | 08:02 AM
iroc3o5's Avatar
where to mount amp?
i just bought this amp to add some power to my infinity 6x9s. thing is, i dont know where i should mount it. i have been thinking maybe i should hide it somewhere like under the seat. where would you guys mount an amp? could i run wires from inside the spare tire well?
Old Dec 18, 2007 | 08:16 AM
LoganTA's Avatar
Car: 87 Silver Formula
Re: where to mount amp?
if you don't use your hatch that much,i say put it back there.
Old Dec 18, 2007 | 09:57 AM
iroc3o5's Avatar
i do use my hatch, frequently. i dont necessarily want the amp to be mounted out in the open.
Old Dec 18, 2007 | 10:40 AM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
this what im going to do
subs pending
Old Dec 18, 2007 | 12:58 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Mine's attached to the bottom of my subwoofer box, which just so happens to fit perfectly into that little trench in the back of the 'trunk.'
Old Dec 18, 2007 | 01:40 PM
iroc3o5's Avatar
mine is about half that size if not less, and i want to HIDE IT
Old Jan 1, 2008 | 11:48 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Under one of the front seats is an option. I worked in a stereo shop for 3 years and I have done that very thing in a couple of other third gens (put sub amp under driver seat and 4ch under the passenger) If you have a tall amp I hope you are short or have t-tops or a vert because sometimes you have to shim the seat up. Always leave air space for cooling. Oh and I do not know if you have power seats but it typically wont fit without modifications.
Or if you rarely have more than 2 people in the car u can build a small box or rack to replace or go under one of the rear seat cushions, if u plan on putting it under then u might want to get some small fans for cooling and build the box strong just incase a heavy friend decides to sit back there. Then u run into the fan noise driving u crazy but when it comes to overheating or an annoying buzz its your call.
Old Jan 2, 2008 | 12:09 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
extremely odd thought...don't know how it would work out, but what about in your rear wheel wells, if you aren't worried about your spare tire, you can put it there, or figure out how to put it on your driver side underneath the glove box, or hell, take out your rear speakers, mount it down low, and then put your rear speaker back in, nothing wrong with hiding it where you can fit it and where wires will go inconspicuously. Good thing about being by the rear speaker is that there is the vents to the outside right there so you know there will be fresh air there. just a couple thoughts if you wanna hide it, otherwise under the seat is the only other real place i would suggest hiding it. It would give ample space and air to it that it wouldn't overheat.
Old Jan 2, 2008 | 07:12 AM
iroc3o5's Avatar
i mounted it in the spare tire well, it's sweet
[/thread]
Old Jan 2, 2008 | 10:01 AM
KBcobra's Avatar
Engine: 3.1L V6
[/thread]
What are your doing with your spare tire?
Old Jan 2, 2008 | 10:15 AM
iroc3o5's Avatar
i dont have a spare tire
Old Jan 2, 2008 | 11:19 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Old Jan 2, 2008 | 12:08 PM
84redta's Avatar
if you don't go far from home and you have someone willing to bring you it once a year if that....then it's ok not to ride around with it, it's just the long trips you need to bring it with you, of which you can easily throw it in the deep hole in the back
Old Jan 2, 2008 | 12:14 PM
iroc3o5's Avatar
i work at AAA. so i can get a tow whenever wherever i want on and wait only 15 minutes max. i have had flats before, but i was always close enough to home, so i just drove home on the flat and changed it with a full size tire myself
Old Jan 2, 2008 | 12:21 PM
84redta's Avatar
well glad you found a good spot...you can also clean it up, create a fiberglass enclosure around it if you wanted so that you can take it off and show it off, otherwise, looks great and you'll enjoy it!! Enjoy!
Old Jan 2, 2008 | 12:50 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
I see engine noise in your future...
Old Jan 2, 2008 | 01:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You see a bad ground?
Old Jan 2, 2008 | 02:07 PM
iroc3o5's Avatar
elaborate.
Old Jan 2, 2008 | 02:42 PM
84redta's Avatar
iroc, where does your ground go to exactly??? looks like the rear bumper mounting screws. I've heard debates on this topic and the idea behind it is the fact that this being a unibody car, you need to put it into a spot that has many big pieces of the car all in one spot, like the subframe that goes right there, not just a think piece of metal such as the spare tire mount as an example. I don't know, i put an amp into the back of my unibody pathfinder last year with no problem, but i don't know where you put it, so both iroc say where you put your ground to, and arrowcamaro ellaborate on your thoughts behind your comment.
P.S. some of his comment may lead towards the fact that your signal RCA wires are zip tied to your power/ground wires. That WILL give you bad interference, experience here , but i figured that out the hard way, moved everything around, and got everything right, difference was night and day. it says in the instructions to have the power wire go up one side of the car and the signal wire on the other side, and by the amp try and keep them apart as much as possible.
Old Jan 2, 2008 | 05:11 PM
Car: '88 GTA
Engine: L-98
Ding!
Old Jan 2, 2008 | 06:41 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I put my amp on my sub box that fits right in the low area of the rear hatch, makes for an easy removal if you need more room.
Old Jan 2, 2008 | 06:51 PM
iroc3o5's Avatar
haha oh yeah i shouldnt have zip tied em together.
ground is the bumper cover screw.
Old Jan 6, 2008 | 03:41 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Under the seat is always nice. Heres a few pics of mine:
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
ynk1121
Sep 12, 2015 12:27 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
