Delco Radio Blues
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Delco Radio Blues
Got the intermittent Delco radio blues. My 86 is a garage queen with 27K on the clock. Started it up this week, and the radio would pop, and crack, but the dial would not come on. The clock continued to read as if the radio were off. The light on the gain switch on the dash would light up, but no other activity noticed. Drove the car for a while, and the radio suddenly started to work. It dropped out a couple of times then stayed on, and worked normally. Any ideas?I know it's a loose connection somewhere, but I am wondering if it is in the radio, or the car. Since the gain switch lights up with the power switch on the radio, I am thinking that it is inside of the radio. It's the model with the AM/FM/Cassette, graphic equalizer. Thanks in advance.
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Re: Delco Radio Blues
I had something very similar happen with the radio from my 88 IROC. Turned out it was the radio & not the car. I ended up having to have the unit repaired. Plays like a champ now. If i remember right the shop that i ended up sending the radio to for the repair was in the carolina's.
Thanks, I see If I can locate them.
That will be great! Thanks
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
id just get a new one from the bonyard, theyre dirt cheap. unless u wanna keep everything original.
