stereo equiptment.
Old Feb 1, 2008 | 04:06 PM
Hartmann's Avatar
stereo equiptment.
my 86 camaro has a jvc stereo and all stock speakers that fuzz when it gets about 15. what kind of stuff should i buy to make it better?
Old Feb 1, 2008 | 05:52 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: stereo equiptment.
replace the speakers, if they are original there probably isnt any surround left. if you are on a budget pioneer base model speakers are decent for the price, if ur looking to spend about 200-250 for all 4 polk dbs are pretty decent all around, if u want more bass the kicker ks series at about the same price. but everyone has their own opinion, i worked for circuit city for 3 years as a stereo installer and those were the best sellers
Old Feb 1, 2008 | 06:50 PM
Hartmann's Avatar
thanks how easy would any of those be to install?
Old Feb 1, 2008 | 10:57 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Some great bang for the buck speakers if your looking slightly 'higher end' are Alpine Type S speakers like we have at Best Buy. But like Jeff91 said, Pioneer's are decent for the price, or even Kenwood's. I wouldn't recommend Sony's, just not good all around sound. I personally ran Infinity systems in my Camaro's... which we sell at Best Buy.
The rear Speakers are EXTREMELY easy to replace. That little 'hanger hook' by the rear seats, just remove that screw and take that carpet'ed panel and slide it up and wa-lah, there's the speaker. Remove 4 screws and the speaker is out.
As for the front speakers, still easy. Remove about 5 or 6 7mm bolts along the front underside of the dash, you may have also have one or two bolts up along the windshield in the defroster vent. After all the bolts are out, the whole entire dash upper dash will slide out towards you.
Old Feb 2, 2008 | 11:39 AM
Hartmann's Avatar
thanks alot. Is there a specific size i should look for to replace all of the speakers? How hard would it be to install a sub and amp?
Old Feb 2, 2008 | 01:10 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
sub/amp should be the easiest because its all open just need to run the wires
Old Feb 2, 2008 | 07:46 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
speakers are 4x6's on the dash and 6x9s in the back. as far as a subamp install, it is a pretty straight forward project the only issue that you will run into is that the plasic on a 22 year old car can tend to get a little brittle so you have to be careful when you remove the plastic panels. I have seen plenty of installs where someone just tried sliding the wires under the panels and for the most part that doesn't work. the wires ultimately work their way out.
Old Feb 3, 2008 | 01:43 PM
Hartmann's Avatar
thanks.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
meeklay812
Oct 1, 2015 03:46 PM
